The meaning of this input?
Old   January 8, 2019, 08:26
Post The meaning of this input?
Saurabh Das
Sorabh is on a distinguished road
Hi, I am applying surface tension to melting of a 3d wall. The top face, which is irradiated by a heat source, has the following option in the boundary conditions:
The "surface tension gradient" option, is used to denote a surface tension coefficient in the fluid.
Now, while studying surface tension in 3D, we have to study it along both of the axis, (x and z in this case)
Does this apply the surface tension coefficient in both x and z directions? If no, then how do I do it?
Sorabh is offline   Reply With Quote
Correct foamfile header for input file with mixed quantities (any version of OF) deepbandivadekar OpenFOAM Running, Solving & CFD 3 February 15, 2021 05:10
Monitor for Pressure BC not same as the input value ! supermanks FLUENT 7 June 3, 2014 08:02
cooler heat input DineshramBalaji FLUENT 4 May 17, 2014 08:04
[OpenFOAM] Paraview 3.98 - errors when saving geometry file pajot ParaView 1 September 28, 2013 10:45
cannot input CATIA *.model into gambit soilinkin FLUENT 10 January 12, 2011 00:47
