How to split the domain in two regions laminar and turbulent in Fluent? |
January 20, 2019, 17:07 |
MH Lee
Rep Power: 7 |
I am trying to test NACA airfoil which has Re=3x10^6 in Fluent. First, I tested with SST K-omega (turbulent model) and compared the results with experimental data. The Cl value was very similar (under 3% error) but the Cd value was around error of 37%. I read one article ("Evaluation of the turbulence models for the simulation of the flow over a National Advisory Committee for Aeronautics (NACA) 0012 airfoil" byDouvi C. Eleni*, Tsavalos I. Athanasios and Margaris P. Dionissios) says if I split the domain into laminar and turbulent regions, I can get much accurate results. However, I have no idea how to split the domain into two regions. If I assume like below picture but we can select only one model like I choose SST k-omega. Is there anyway I can specify two models, one for laminar and turbulent? https://ibb.co/BsKrYDt |
January 21, 2019, 08:14 |
Lucky
Rep Power: 66 |
Select your turbulence model in the viscous model.
You need two cell zones. One for the laminar and one for the turbulent. Then go to cell zone conditions and specify that region as a laminar zone. |
January 21, 2019, 14:03 |
MH Lee
Rep Power: 7 |
Thank you, LuckyTran.
I will try that |
January 24, 2019, 04:28 |
#4 | |
MH Lee
Rep Power: 7 |
I managed to separate the flow zone into laminar and turbulent. It did decrease my drag coefficient value a lot. However, my lift and drag values were started to fluctuate from 8 degrees AOA and so on. I don't know why it happened. Is it because I did not predict transition point correctly? (maybe turbulent zone is larger and it created large wake which caused fluctuating values?) Please help. |
September 19, 2019, 12:55 |
gautam
Rep Power: 6 |
hello Mihylee,
Am also facing the same problem. the values of lift and drag coefficients are fluctuating at an angle of 9 degree. i tried changing the transition points on the both surfaces of an airfoil. still couldnt get any positive outcomes. did u solve the case? regards gautam |
April 28, 2022, 09:15 |
Unable to separate the flow regions
Suman Ray Pramanik
Hi everyone,
I cannot separate the flow region into laminar and turbulent for an airfoil. Would you guys help me out with the necessary proceedings for achieving this? Thank you and Warm regards |
CFX Treatment of Laminar and Turbulent Flows | Jade M | CFX | 18 | September 15, 2022 07:08 |
Turbulent flow entering laminar domain | arjdk | FLUENT | 0 | November 21, 2017 04:38 |
Why can i use a laminar solver for a turbulent flow? [Heat transfer problem] | blackbow | CFX | 1 | November 22, 2016 04:42 |
Defining regions of laminar and turbulent flows | raven | CFX | 7 | July 31, 2015 00:24 |
laminar and turbulent flow in two regions | mozafarie | FLUENT | 0 | March 11, 2013 13:42 |
