February 11, 2019, 07:37 |
Negative Energy
Roland Janoyan
Rep Power: 7 |
When can fluent show negative energy in volumes?
In case we have 3 materials concrete, steel and air. All materials initializated as 273.15 K temperature. |
February 11, 2019, 07:49 |
It depends on the reference point
Moritz Kuhn
Rep Power: 17 |
As the internal energy, like the enthalpy, of a system cannot be measured directly you only deal with the diffrence between different states. Internal energy is a thermodynamic potential, so in order to measure the enthalpy of a system, you must refer to a defined reference point; therefore what we measure is the change in internal energy, ΔU. So start your calculation and see how the values will change.
February 11, 2019, 08:48 |
Roland Janoyan
Rep Power: 7 |
In my case at 0 timepoint I have positive temperature and then it will become negative. After Initialization I plot Mass-average total energy of air and concrete, both are negative. By patch I give them +25°C temperature, Mass-average total energy of concrete become 0 j/kg, but air energy become -99966 j/kg. Air Total energy become 0 j/kg at about 416 K.
February 11, 2019, 09:10 |
Moritz Kuhn
Rep Power: 17 |
Be careful with patching values in selected cells. After that you will not have a valid solution in most cases. After patching you have to run the solver until convergence to calculated all temperature depending (or other variables wich are dependend of the patched property) properties properly.
February 11, 2019, 09:40 |
Roland Janoyan
Rep Power: 7 |
Dear Kuhn finally what you advice me, how to solve problem with ploting energy in material?
February 11, 2019, 09:56 |
Moritz Kuhn
Rep Power: 17 |
See attached pictures
--Moritz |
February 11, 2019, 10:12 |
Roland Janoyan
Rep Power: 7 |
Thanks. I will try )
February 12, 2019, 06:07 |
Roland Janoyan
Rep Power: 7 |
I attach Data Total Energy, Temperature and Mass of air and building part at 2000 and 10000 seconds
10000 sec.PNG 2000 sec.PNG |
February 13, 2019, 09:04 |
#9 |
Roland Janoyan
Rep Power: 7 |
Sorry but fluent take reference(where energy =0) temperature for air as ≈416 K and for concrete 298.15. How can I change it?
February 13, 2019, 10:31 |
#10 |
Moritz Kuhn
Rep Power: 17 |
You dont have to change it. Absolute values of enthalpy or energy are quite useless, as you work only with the difference of these values between two states. It is also ok, if these values are negative.
Check user or theory guide of fluent if you can change the reference state. But in my opinion it is not necessary. |
Natural convection, problems with total energy balance | MdoNascimento | STAR-CCM+ | 0 | March 13, 2014 12:15 |
channelFoam for a 3D pipe | AlmostSurelyRob | OpenFOAM | 3 | June 24, 2011 13:06 |
blockMesh error ... | balkrishna | OpenFOAM Pre-Processing | 0 | August 17, 2010 02:39 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
