Does a larger number of iterations for steady state gives better result?
Old   March 3, 2019, 00:09
Default Does a larger number of iterations for steady state gives better result?
cfdnewb123 is on a distinguished road
Hi i am new to CFD so forgive me if this is a dumb question. I am working on supersonic impinge flow using steady-state and I managed to captured the shock wave as described by the paper. However that is provided that my no. of iterations is not too large. If my no. of iterations is too large, the result will show some weird result, usually no flow is shown. If I reduced that iterations, i will get a good result. I thought that if I increase the iterations, the result will be better as the solution got more iterations to stabilize.
When I increase my velocity at inlet, the no. of available iterations that I can use decrease too.
cfdnewb123 is offline   Reply With Quote
Decomposing meshes Tobi OpenFOAM Pre-Processing 22 February 24, 2023 09:23
Maximum number of iterations exceeded chtmultiregionsimpleFoam Moncef OpenFOAM Running, Solving & CFD 28 July 13, 2020 14:26
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops avinashjagdale OpenFOAM Meshing & Mesh Conversion 53 March 8, 2019 09:42
simpleFoam error - "Floating point exception" mbcx4jc2 OpenFOAM Running, Solving & CFD 12 August 4, 2015 02:20
Cannot run the code properly: very large time step continuity error crst15 OpenFOAM Running, Solving & CFD 9 December 14, 2014 18:17
