OSI, AAWSS, TAWSS calculation
Like Tree1Likes
  • 1 Post By Noushin
Old   March 28, 2019, 13:27
Question OSI, AAWSS, TAWSS calculation
Noushin anan
Noushin is on a distinguished road
Hello
Can anyone help me on how can I calculate OSI,Ig factor, Area averaged wall shear and time averaged wall shear in Ansys fluent?
I'm doing my thesis on hemodynamic parameters on left coronary artery.
If more details is needed kindly ask me
Thank you
Noushin is offline   Reply With Quote
Old   June 3, 2024, 01:35
Smile OSI calculation
Parham Vatankhah
Parham Vatankhah is on a distinguished road
Dear Noushin,
Have you found out how to calculate OSI?
Cheers,
Parham
Parham Vatankhah is offline   Reply With Quote
Old   June 4, 2024, 12:52
Noushin anan
Yes, I found a way.
Thanks.
rootC likes this.
Old   June 20, 2024, 08:31
rootC is on a distinguished road
Originally Posted by Noushin View Post
Yes, I found a way.
Thanks.
Hi @Noushin , I am working on a similar FSI problem , and I want calculate TAWSS , OSI and RRT , I am currently calculating TAWSS in CFD post using expression ,and its working but can you help me with the expression of OSI ?
I am currently using this formula for OSI , let me know if its correct
OSI = 0.5*(1-((abs((Wall Shear X.Trnavg)+(Wall Shear Y.Trnavg)+(Wall Shear Z.Trnavg)))/((abs(Wall Shear X.Trnavg))+(abs(Wall Shear Y.Trnavg))+(abs( Wall Shear Z.Trnavg)))))
Warm regards
rootC is offline   Reply With Quote
Old   June 20, 2024, 09:01
Martin_Sz's Avatar
Marcin
Martin_Sz is on a distinguished road
You can try to follow these steps below
https://howtooansys.blogspot.com/202...ctor-area.html
Quick Tips and Tricks, Tutorials FLuent/ CFX (CFD)
Martin_Sz is offline   Reply With Quote
Old   June 27, 2024, 13:55
Noushin anan
The formula I used was, 0.5*(1-(sqrt(Wall Shear X.Trnavg^2+Wall Shear Y.Trnavg^2+Wall Shear Z.Trnavg^2)/Wall Shear.Trnavg )). I believe you can use this one, if do did not get your expected results using the other formula.
TAWSS and OSI calculations via MATLAB amsys CFX 1 March 4, 2019 18:11
Dynamic mesh adaption in parallel calculation xh110120 FLUENT 1 March 12, 2016 09:05
Determining the calculation sequence of the regions in multe regions calculation peterhess OpenFOAM Running, Solving & CFD 4 March 9, 2016 04:07
MRF and Heat transfer calculation Susan YU FLUENT 0 June 2, 2010 09:46
Warning 097- AB Siemens 6 November 15, 2004 05:41
