Advice for modeling nozzle-like geometry in fluent
Old   April 9, 2019, 11:38
Default Advice for modeling nozzle-like geometry in fluent
Nicholas WIlliams
nikolai4876 is on a distinguished road
As part of my graduate research, we designed a nozzle like geometry that vibrates quite strongly when water flows through it. I would like to model this in fluent but I'm not really sure where to begin, I have run some simulations using different techniques such as changing the turbulence model, or modeling it in 3D as well as 2D, but it seems like I get different results with different models and techniques. I attached a picture of the 2D cross section.
nikolai4876 is offline   Reply With Quote
Old   April 10, 2019, 09:44
Lucky
LuckyTran has a spectacular aura aboutLuckyTran has a spectacular aura aboutLuckyTran has a spectacular aura about
Try running the simulation on Sunday.
Before doing anything investigative, you need to normalize your experience with Fluent first.
LuckyTran is online now   Reply With Quote
Old   April 10, 2019, 11:08
Nicholas WIlliams
I have pretty good experience with the Fluent interface actually. I know how to design in design modeler, creat my mesh and setup the simulation in fluent. I'm just not sure what the best turbulent models, iterations settings, etc. would be.
Old   April 18, 2019, 10:11
Pramod Narayan
pramodnarayan is on a distinguished road
Hi Nikolai,
When it comes to modeling a nozzle, having a good mesh is critical to obtaining a good solution. The mesh at the nozzle tip should be fine enough to capture the pressure gradient and the shock. The boundary layer needs to be refined with atleast 15-20 cells. Looking at your model, you can obtain a nice Hexahedral mesh aligned in the direction of flow. You just need to decomposed the model.
Try using a density based solver with your time step adjusted based on the Courant number. Review your boundary settings carefully. Set the initial gauge pressure appropriately. I have generally had good experience using the SST K W turbulence model. If you observe divergence behavior initially, start with transient mode and then change over to steady state.
Good Luck
pramodnarayan is offline   Reply With Quote
How to go about modeling injection nozzle two phase flow in FLUENT? skonda2 Fluent Multiphase 0 March 17, 2015 07:52
Problem in using parallel process in fluent 14 Tleja FLUENT 3 September 13, 2013 10:54
problem in using parallel process in fluent 14 aydinkabir88 FLUENT 1 July 10, 2013 02:00
Different flow patterns in CFX and Fluent avi@lpsc FLUENT 4 April 8, 2012 06:12
analyze a cd nozzle with fluent which designed by MOC mehrzad Main CFD Forum 0 July 6, 2011 04:33
