Nusselt number calculation in Fluent
Like Tree20Likes
Old   June 20, 2008, 10:15
Default Nusselt number calculation in Fluent
Sharadkumar Yeri
Dear all, I am simulating flow and heat transfer in a rectangular duct with some kind of roughness.I need to calculate Nusselt number at the heating surface.The heat transfer is forced convection. I tried to calculate Nusselt number using Report>Surface integrals>Surface nusselt number
But the Nusselt number I am getting is absurd.Is there any way to calculate Nusselt number?
Thanks with regards
Sharad
shariful and Ahmed Fakhrey like this.
Old   June 20, 2008, 10:25
Default Re: Nusselt number calculation in Fluent
red lemon
Use a custom field function calling h for use in hD/k. h can be surface based or wall function based.
I suspect default h values for Nu call surface based h and use the reference temperature in the reference values panel so you may need to only adjust this. It may also by default use the reference length for D in the calc of Nu which may also need adjusting from the default (defined in same panel as the ref temperature).
f.kh likes this.
Old   June 20, 2008, 10:43
Sharadkumar Yeri
Hi Red Lemon You mean to say,if I need to calculate average Nu of the duct,note down Area weighted average of Surface heat transfer coefficient of the face of which I need Nu and just multiply by D/k ?
Thanks
Old   June 20, 2008, 11:45
red lemon
Well I was meaning so you could plot Nu over the surface as a contour but if you want a single value as an average for the wall zone then just take the average h value from report surface integral and multiply by D/k but make sure reference values are correct for h(avg) calculation. D is the hydraulic diameter for internal flows but use L for external.
f.kh and hamidreza.nb4 like this.
Old   June 20, 2008, 12:04
Sharadkumar Yeri
Hi Red Lemon Thanks for the information.I have not changed any reference value.Its default setting.Do I need to change reference values and run the model again?
Thanks
Old   June 20, 2008, 12:18
red lemon
no, reference values are just for post processing so if you plot htc's using one reference value then change the reference value then plot again the results will be different as its just a post calc operation and no extra iterations are required.
You need to select an appropriate reference length scale (for Nu) and reference temperature (for h).
f.kh likes this.
Old   June 20, 2008, 13:34
Sharadkumar Yeri
Hi Thanks for you quick response. You mean to say, in Reference values panel,I need to substitute values for
Area= Surface area of heat transfer for which Nu to be calculated
Length=Hydraulic diameter
Temperature= Temperature of air at inlet
Velocity= free stream velocity
Since I have not used Reference values, I have these doubt. Your help is highly appreciated.
Thanks with regards
Sharad
f.kh likes this.
Old   June 20, 2008, 13:45
red lemon
Correct. Be careful that for reference temp you could use inlet temp, outlet temp, bulk mean fluid temp, near wall fluid temp etc so htc values are quite arbitrary and will give different values depending on what ref temp you use. This is why I prefer to plot fluxes (Q) instead.
Use the same reference temp as used in the calculation of h for your experiements if you have xp data. I think you only need the first 3. reference velocity is used for lift and drag.
f.kh likes this.
Old   June 20, 2008, 15:01
Sharadkumar Yeri
Thanks a lot for your so valuable and quick response.
Thanks with regards
Sharadkumar
Old   June 23, 2008, 06:24
Rakesh Jha
Sharad I dont know in what way you are trying but here is what I would do: (i)Create a line (iso-surface of grid at the mid of the wall) (ii) Plot-> XY -> Wall fluxes -> Total surface heat flux (assuming radiation is not on) as Y-co-ordinate and channel length as x-co-ordinate. (q). write this!
(iii) craete another line at the centerline of the channel. (iv) Tcenterline, extract teperature vs channel length as in step (ii). (Write this!)
(v) What wall thermal Bc you have, if it is const heat flux then extract wall temperature vs channel length (you can use the same line this time which was created for heat flux). if the wall Bc const wall temp then no need to do this step.
(vi) Now obtain h = q/(Twall-Tcenterline). then Nu = h*D/k
(vii) if you have fluid with varying properties 9say incomressible ideal gas) then be careful of talking that into count wh8ile doing step (vi).
I think Nu calculated in this manner can be comparable to literature (I guess your case matches closely with Dittus-Boelter correlation).
Please note that your centerline temperature is chaning with the cordintae along the channel length. so fixing the reference temperature (in fluent) may not serve the purpose. All the best!
Oula, pky3038, O.SEUNG-MIN and 7 others like this.
Old   June 23, 2008, 14:26
  #11
red lemon
I think Sharad is looking for an avg surface Nu value rather along a line mid wall though this process is good to demonstrate decaying htc or Nu along the surface in the streamwise direction as it accounts for varying gas temp as well as wall temperature. As I mentioned, you need to concur with the method for which the data was reduced for the experiment. Note in this case Tref=Tcentreline but Tref could be near wall gas temp or bulk fluid mean temp etc.
Old   June 23, 2008, 14:29
  #12
Sharadkumar Yeri
Hi Rakesh Thanks for the reply. I have done almost same as you have mentioned. My flow is incompressible and with constant heat flux.I needed to shown variation of Nu along the length of plate. So I created a line at the mid plane at the heated surface. This will have temperature values. I calculated mean temperature of fluid in the duct. In FLUENT is reference value, I changed area of HT, Length as Hyd dia. and temperature as mean temperature of the fluid. Then I can use this Nu from Fluent for my analysis.I also needed avarage Nu for the duct for particular flow rate.So this methods served both purpose.
As you have mentioned in step (iv), use of center line temperature for calculation of Nu. I guess this does not suit to my problem.
Comments are highly appreciated.
With regards
Sharad
Old   February 14, 2010, 04:09
Mohammad Zakerzadeh
moh1367 is on a distinguished road
Hi guys!
My case is very simple , its laminar flow in a pipe with constant wall temperature. I take the length as long as the flow can reach to fully thermally and Hydrodunamically developed. When I get the Nusselt Number from the xyplot/Surface Nusselt Number it can seemed that the Nu begins from a large number(as predicted by theory) and go toward zero at the end of pipe (the theoric value is 3.66). Can anybody help me?
I can send my case to you for more information.
Thanks alot
moh1367 is offline   Reply With Quote
Old   August 8, 2010, 06:27
Default hello
  #14
hassan
hassan79 is on a distinguished road
hi
r u used turbulent folw ? and r u used k omeg or k epslon ?
Originally Posted by Sharadkumar Yeri
;151656
Thanks with regards
Sharad
hassan79 is offline   Reply With Quote
Old   August 8, 2010, 06:32
Default hello
  #15
hassan
i want simulate heat transfer in sudden expansion pipe and calculate surface nusselt numbr
turbulent flow .
can u help me wich model to my case k omega sst or k epslon relizable
Originally Posted by hassan79 View Post
hi
Old   October 14, 2010, 06:48
sajid
mskamran is on a distinguished road
Hello bro,
I am trying to find NUSSELT NUMBER around a cylinder. I have constant heat flux at the cylinder surface.
I am doing XY-Plots>Wall Flux>Surface Nusselt Number to find the nusselt number.
My results are not good.
Can you please advise me how to do this? or any good reference to do this? Your help would really appreciated!
Thanks
mskamran is offline   Reply With Quote
Old   August 28, 2012, 01:46
Default heat transfer coefficient error
  #17
abc
abc
abc is on a distinguished road
Hey, i was doing a problem in fluent on a bifurcating t-junction with a heated bottom plate of the side branch. On doing heat transfer upon this geometry i am facing a problem that the results for surface heat transfer coefficient plot for heated plate which i get under wall fluxes is coming out to be different from that when i calculate it like this:
h=q/(Tw-Tf)
where q is total surface heat flux
Tw is the heated wall temperature
Tf is the fluid temperature
q was also taken from the plot of total surface heat flux for heated plate under wall fluxes.flow is incompressible.
plzz help mee out
abc is offline   Reply With Quote
Old   August 28, 2012, 02:06
Mohammad Zakerzadeh
Fluent (at least up to version 6.3. I have worked on) has a bug on heat transfer post processing calculation.
In Nusselt number calculation we usually use T*m (instead of Tf... it refers to what? No idea!), which is the average temperature weighted by mass flow rate (c.f. Incropera book for example), but fluent just uses some constant values defined in the reference value (in the report tab).
I think it is better to define some function to calculate T*m in Fluent and then calculate and define additional function for Nusselt calculation based on it.
Also it is better to take a look at the reference values in Fluent, maybe it helps.
Good luck
Mohammad
h=q/(Tw-Tf)
plzz help mee out
nenazarian likes this.
Old   September 7, 2012, 16:45
Negin Nazarian
nenazarian is on a distinguished road
Hi Mohammad
I found your previous post to be very useful since I myself am suffering from heat transfer coef and Nu# calculation.
My question right now is about Total surface heat flux:
does it account for all Radiation/Convection/conduction?
I am accounting for all of these in my case but Im confused on how to check the heat balance using fluent values.
I would appreciate your help.
Cheers
Negin
nenazarian is offline   Reply With Quote
Old   September 7, 2012, 17:14
Mohammad Zakerzadeh
Hi Negin...
Happy to hear that it helps...
Regarding your question, I am not quite sure I got what you exactly mean by heat balancing in Fluent, it is better if you can explain more about your case, its BCs and the values given by Fluent in post processing.
(And also the reference values.... have you checked them?)
About total heat transfer I suppose that it should consider all effects as you assumed.
Mohammad
Originally Posted by nenazarian View Post
Hi Mohammad
Cheers
Negin
Nusselt number calculation Uttom Roy COMSOL 0 July 29, 2006 07:36
nusselt number calculation john Main CFD Forum 1 October 12, 2005 05:20
nusselt number procedure in fluent muhkiraz FLUENT 2 December 29, 2003 06:04
Nusselt Number calculation jiehai Zhang FLUENT 1 April 8, 2002 17:35
Fluent formula for Nusselt number Alan FLUENT 1 May 29, 2001 12:50
