Saving data transient simulation - file format
Old   June 21, 2019, 04:55
Question Saving data transient simulation - file format
Daniel Piņeiro
batdan is on a distinguished road
Hello everyone!
I´m doing an FSI simulation of an aircraft wing. I'm using Fluent 19.1 in parallel (linux cluster) for the CFD and Matlab for the coupling with the structural side. It's a dynamic simulation, so, basically, what I do is execute Fluent in batch mode, from Matlab, calculate one time-step, export the loads, exit Fluent, calculate the deformation, execute Fluent, deform the mesh using UDF, calculate one time-step... and so on.
The problem is that for every time-step the case and data have to be saved, what takes some time since the mesh has 4.6 million cells. So, the question is: which should be the best data file format to spend the least time as possible reading and writing?
I tried with .h5 format, but I'm not sure if there is a real improvement. In addition, I found that the graphic contours aren't available afterwards (can anyone confirm this?).
Thank you!!
batdan is offline   Reply With Quote
data file format, fluent, fsi, quick save, transient
[Other] Tabulated thermophysicalProperties library chriss85 OpenFOAM Community Contributions 62 October 2, 2022 03:50
how to calculate mass flow rate on patches and summation of that during the run? immortality OpenFOAM Post-Processing 104 February 16, 2021 08:46
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 Seroga OpenFOAM Community Contributions 9 June 12, 2015 17:18
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 16:02
[swak4Foam] funkySetFields compilation error tayo OpenFOAM Community Contributions 39 December 3, 2012 05:18
