Max Iterations per Time Step What does it really mean |
July 8, 2019, 20:04 |
Amir
Rep Power: 7 |
Hello all,
In Fluent for unsteady formulation FLUENT uses implicit time discretization and the FLUENT guide says they use iterations between two time steps so they have Max Iterations / Time Step as an input. My questions is this iteration is done on the coupling between u & p? they update u and p, n times (number of iterations) in each time-step and then move on to another time step? Thank you |
July 8, 2019, 22:26 |
#2 | |
Lucky
Rep Power: 66 |
The short answer to your question is probably yes. The coupling between u & p is determined by your pressure-velocity coupling algorithm (SIMPLE,PISO,COUPLED,etc. or other if you are using a density-based solver). A more politically correct answer is that it's the number of times the implicitly under-relaxed equations has been solved (which can also include energy equation, phase equations, and many other equations in addition to just u & p). An implicit temporal discretization gives a system of linear equations which in principle can be solved exactly (not requiring any iterations). However, fluent also uses implicit under-relaxation (which requires several sweeps/steps/iterations to converge to the desired time-step). |
[solidMechanics] Support thread for "Solid Mechanics Solvers added to OpenFOAM Extend" | bigphil | OpenFOAM CC Toolkits for Fluid-Structure Interaction | 686 | December 22, 2022 09:10 |
Micro Scale Pore, icoFoam | gooya_kabir | OpenFOAM Running, Solving & CFD | 2 | November 2, 2013 13:58 |
pimpleFoam: turbulence->correct(); is not executed when using residualControl | hfs | OpenFOAM Running, Solving & CFD | 3 | October 29, 2013 08:35 |
pisoFoam with k-epsilon turb blows up - Some questions | Heroic | OpenFOAM Running, Solving & CFD | 26 | December 17, 2012 03:34 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 18:07 |
