Problems of plotting chart of massflow vs y in cfd post |
August 3, 2019, 03:22 |
Tzu Yu,Lin
Rep Power: 6 |
Hi, everyone. I want to plot mass flow vs y of inlet but it still shows zero. Here's my method, plz name any mistakes I've made or any concern.
1. Create a 2D line,named it as "line one", and specified line type as cut. 2. Pick the data source at "line one". 3. Choose X Axis as "Y". 4. Choose Y Axis as "MassFlow".(This variable didn't appear as I click on the drop-down menu. I selected "MassFlow" in addition.) But when I use function calculator it can calculate the right mass flow. I've looked up all kind of threads or articles related to this kind of problem and tried it. But the chart still shows zero. Thank you for reading my thread. Best regard. Last edited by yorkatmars; August 3, 2019 at 06:03. |
August 14, 2019, 12:35 |
why dont you plot velocity and convert it to mass flow
August 14, 2019, 19:44 |
Svetlana Tkachenko
Rep Power: 14 |
What is the location of that line?
August 19, 2019, 05:37 |
Tzu Yu,Lin
Rep Power: 6 |
the location is at the inlet.
August 19, 2019, 05:38 |
Tzu Yu,Lin
Rep Power: 6 |
How? Can I multiply velocity by density and area and plot it?
August 21, 2019, 04:11 |
Rep Power: 10 |
I guess your problem is on how the mass flow is calculated in your function calculator. The mass flow is not a field variable, you need the surface area to calculate the mass flow. Usually this is done with a surface integration. And as your nodes, do not have an area, it is impossible to calculate a mass flow at the nodes.
You can try to calculate the mass flow per mesh-cell at the boundary. m=rho*u*A, with A:area of the cell. But I don't know how to calculate the area of the cell. Maybe Fluent is capable on exporting the cell-area. |
Plotting the Viscosity Contour in CFD Post | ashtonJ | FLUENT | 3 | June 2, 2015 12:06 |
CFD Post Streamlines better representation? | Dr. Flow Squad | CFX | 2 | January 20, 2014 13:48 |
Parallel process & CFD POST | jypark | FLUENT | 2 | August 14, 2013 23:49 |
CFD Post Expression over time chart (without monitor point) | Badi | CFX | 1 | July 17, 2013 17:22 |
CFD for fans & blower housings | David Carroll | Main CFD Forum | 8 | August 24, 2000 17:25 |
