Inflation Layers on 3d aircraft
Like Tree1Likes
  • 1 Post By canogerardo55
Old   August 2, 2019, 19:01
Default Inflation Layers on 3d aircraft
Aurelio
canogerardo55 is on a distinguished road
Hello everyone,
I am currently doing an aircraft simulation in Fluent and have done so successfully, but without the use of inflation layers on the aircraft.
Once I add these layers, the orthogonal quality and skewness of the mesh drop considerably in the trailing edge (sharp corner) and I cannot use this mesh for the setup I have created.
I have also read that dividing the domain can help in this, but I don't know where to start, as the trailing edge of the aircraft is a little complex to sketch.
Here are some images of the mesh and a dropbox link to the workbench file: https://www.dropbox.com/s/bek071zcmj...raft.wbpj?dl=0
Any help would be greatly appreciated,
Regards,
Aurelio.
Светлана likes this.
canogerardo55 is offline   Reply With Quote
Old   August 3, 2019, 00:11
Svetlana Tkachenko
Светлана is on a distinguished road
Are you creating the geometry in DesignModeler?
Add a new plane, split the wing surface by this new plane using 'Tools > Split Face' option. Then in the mesh add a face sizing control (Mesh > insert > Sizing, select a face) on different parts of the wing surface as needed.
Светлана is offline   Reply With Quote
Old   August 5, 2019, 16:13
Aurelio
I created the geometry in Solidworks, but I will try the solution with the imported model in DesignModeler.
I have tried the sizing options (0.005m) without the plane division, and it has certainly increased the quality of the mesh in the aircraft.
Thank you,
Aurelio
aircraft design, inflation layers, mesh 3d, trailing edge
[ANSYS Meshing] Inflation layers element quality frossi ANSYS Meshing & Geometry 0 July 2, 2016 20:19
[ANSYS Meshing] Inflation Layers Being Finicky Markua ANSYS Meshing & Geometry 12 April 28, 2015 07:11
[ANSYS Meshing] Inflation Layers disappearing - airfoil krekel13 ANSYS Meshing & Geometry 0 January 24, 2015 13:55
Fluent diverges when using inflation layers ziggo FLUENT 4 August 9, 2013 12:11
how to set turbulence model and inflation layers in analysis of an aircraft realpilot FLUENT 2 April 24, 2013 20:26
