Converting .msh file back to geometry
Old   July 19, 2014, 09:37
Default Converting .msh file back to geometry
Ed Moses
edmoses is on a distinguished road
Dear All,
I just did an optimization of geometric form using the adjoint solver and the mesh morpher. Now, I would like to extract the optimized geometry for further use. Can anyone suggest a way of doing this?
Many thanks and best regards,
Eduard Moses
edmoses is offline   Reply With Quote
Old   February 24, 2015, 07:26
Fredrik Thelin
freth469 is on a distinguished road
Hi!
I see that it was a while ago you posted this. Did you ever manage to export your mesh to a cad-file? I am in the same posistion now since i am currently working with the adjoint solver in my master thesis.
freth469 is offline   Reply With Quote
Old   February 24, 2015, 09:38
Default Converting mesh to CAD
Ed Moses
I did it using a very old Fluent tool called Gambit. In gambit you can import a mesh and reconstruct the underlying CAD as faceted surfaces. You can, then, export this as STL and convert to something else or work on it locally.
Old   June 24, 2015, 07:59
revilo82 is on a distinguished road
Export the msh as STL (script in Fluent or you can use Fluent Meshing (no poly!)). Import the stl to SpaceClaim. Now you can create a surface / volume body with facets or you start with reverse engineering in SCDM.
revilo82 is offline   Reply With Quote
Old   September 5, 2019, 10:46
MIDHUN
MIDHUN@CFD is on a distinguished road
Send a message via Skype™ to MIDHUN@CFD
when we open stl file in spaceclaim we will not be able to save the same file as step in spaceclaim
MIDHUN@CFD is offline   Reply With Quote
adjointshapeoptimization, geometry, morphing, optimization
[swak4Foam] groovyBC in openFOAM-2.0 for parabolic velocity bc ofslcm OpenFOAM Community Contributions 25 March 6, 2017 10:03
what is swap4foam ?? AB08 OpenFOAM 28 February 2, 2016 01:22
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 16:02
[swak4Foam] build problem swak4Foam OF 2.2.0 mcathela OpenFOAM Community Contributions 14 April 23, 2013 13:59
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
