September 20, 2019, 07:46 |
Defining Pressure in Boundry Condition
Mustafa Abba Imam
Rep Power: 6 |
Hello Everyone
I am using a mass flow inlet and pressure outlet boundary condition for a U-shape pipe I am supplying a Heat-Flux to the bottom wall of the pipe to heat the working fluid at a steady state with an inlet pressure of 598000 pascals and mass flow rate of 3.7kg/m-s. operating pressure fixed = 0 and left Guage Pressure at the outlet as = 0 Assuming the output is not vent to air, please how can I determine pressure drop. Secondly, do I need to assign some value at the outlet Guage Pressure? because what am getting is zero (0) as output during simulation Thirdly, I am getting some values for the total pressure (2733). could this be the pressure drop? thank you |
September 28, 2019, 12:24 |
#2 | |
rampada rana
Rep Power: 8 |
What is the usage of inlet pressure in the mass flow inlet and pressure outlet boundary conditions? If you want to pass the required mass under the above inlet pressure, better to use pressure inlet and outlet BCs and check for the mass flow. pressure drop=inlet pressure-outlet pressure best regards rampada |
October 2, 2019, 08:36 |
Mustafa Abba Imam
Rep Power: 6 |
noted.. thank you very much for your input/clarification
Wind tunnel Boundary Conditions in Fluent | metmet | FLUENT | 6 | October 30, 2019 12:23 |
What is difference between static pressure and gauge pressure? | aja1345 | FLUENT | 1 | July 20, 2018 20:05 |
question regarding LES of pipe flow - pimpleFoam | Dan1788 | OpenFOAM Running, Solving & CFD | 37 | December 26, 2017 14:42 |
Static pressure boundary condition | smb | FLUENT | 0 | May 11, 2015 09:00 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
