Porous Media modeling
Like Tree11Likes
Old   August 28, 2010, 15:56
Default Porous Media modeling
Rupak
rupakbanerjee is on a distinguished road
How do i define a region to be porous?
I was working with the tutorial part 8, 'modelling flow through a porous media'. The only thing i did not understand is whether the region has to be defined as being porous while it is modelled in Gambit, or do i just create a meshed volume and define it as porous when i import it to Fluent.
I can only proceed once i know how to create the porous media.
thanks for the help
Takue likes this.
rupakbanerjee is offline   Reply With Quote
Old   August 31, 2010, 17:15
symon
s25011 is on a distinguished road
I built the region as fluid in gambit and then define it as porous in the boundary conditions!
thanks for the help
s25011 is offline   Reply With Quote
Old   August 31, 2010, 17:34
Rupak
when you say you defined it as porous boundary condition, do you mean using the porous jump as the boundary conditio?
Old   September 4, 2010, 04:39
Mansureh is on a distinguished road
hi
If you want to model flow in a porous medium in fluent, you should specify the zone as fluid zone in gambit, and then in "cell zone conditions" dialog box, enable porous zone check box , and specify related parameters such as porosity.
good luck
6863523 and ali_reza like this.
Mansureh is offline   Reply With Quote
Old   November 18, 2010, 02:16
oky
Oky Andytya
oky is on a distinguished road
As i know the parameter in porous zone is inertial and viscous resistance.
How to define it?
Is there any formula or something?
Would you like give an example.
Thank you. Danke.
oky is offline   Reply With Quote
Old   November 18, 2010, 15:30
Rok Sibanc
snow is on a distinguished road
http://www.cfd-online.com/Wiki/Fluen...e_drop_data.3F
chaitanyaarige and BlnPhoenix like this.
snow is offline   Reply With Quote
Old   November 22, 2010, 22:49
Question
oky
Oky Andytya
My porous media is a cell zone
I did't use porous-jump, may be any formulation or something ?
Old   November 23, 2010, 06:11
Rok Sibanc
Yes but for the porous zone (cells) has two parameters (viscous resistance and inertial resistance) that you have to specify. And you determine these two from the pressure drop vs velocity profile using the equations at the link.
Old   December 2, 2010, 06:17
Wink
Nelly
nelly is on a distinguished road
How to define it?
Thank you. Danke.
Hi Oky, did you get to find the parameters?
If not, here is the explanation.
The formula is
Dp/L= [(viscosity/alpha)*velocity]+ [C2*1/2*density*velocity^2]
(dp/l =viscousr resistance + inertial resistance)
and
plot dp/l vs velocity in excel. The pressure drop can be obtained from cfd.
The values for velocity can be arbitrarily chosen say for ex. 0 to 20 m/s (even more if you want more points)
Plot Dp/L vs velocity based on above formula and examine the curve how it looks like. If it is a straight line then use only dp/l=viscous resistance.
If it is a quadratic equation use (dp/l =viscousr resistance + inertial resistance). Find K and C2 with these curves.
Hope this helps .
cheers
Nelly
chaitanyaarige, Andriy70 and Takue like this.
nelly is offline   Reply With Quote
Old   December 20, 2010, 03:01
oky
Oky Andytya
How to calculate the diameter particle [Dp] if i use Ergun or Blake-Kozeny equation to define inertial resisitance and porosity? [see ANSYS Fluent 6.3 User's Guide - 7.19.6]
Blake-Kozeny Equation:
P/L={150*mu*(1-e)^2}/{Dp^2*e^3}*V$
where:
P/L : Pressura drop
mu : viscosity
e : void fraction
Dp : Perticle diameter
V$ : Velocity unlimited
Thank you !
Regrads
OKY
Old   December 20, 2010, 04:25
Nelly
where:
P/L : Pressura drop
mu : viscosity
e : void fraction
Thank you !
Regrads
OKY
Hi This is the reply given by Mr. Jayaprakash in a previous thread discussion,
The Ergun equation assumes that the bed is filled with uniform sized and shaped particles. The sphericity parameter is used as a conversion factor for non-spherical particles (comparing the surface-volume ratio of those particles to an equivalent spherical particle).
Of course, for fully spherical particle, the sphericity = 1.
Sphericity = (6/Dp)/(Sp/Vp)
Dp = Diameter of the particle
Sp = Surface area of the particle
Vp = Volume of the particle
For 'not so crazy' shapes, like sand particles, you can use sphericity around 0.8 - 0.9.
Complete list of sphericity values can be found in "Perry's Chemical Engineers Handbook", or "Unit Operations of Chemical Engineering by McCage, Smith and Harriot" or similar books
Andriy70 likes this.
Old   December 21, 2010, 20:56
oky
Oky Andytya
How to calculate the heat transfer in porous media [for conduction and convection heat transfer]?
Thank you,
Regrads
OKY
Old   February 1, 2011, 20:53
oky
Oky Andytya
Hi everyone,
I'm trying simulation porous media in rectangular channel, but the result isn't suitable with any research.
So, would you help me. I wish someone can check my simulation and give some reports if there is something wrong.
Thank you for your help.
Please send your e-mail, than i will send you my works to to your email.
my e-mail: oky.andytya.net@gmail.com
Regrads,
OKY Andytya P
note:
I use ANSYS Fluent 6.3 [CFD]
Old   May 20, 2011, 03:42
M. A.
motahar is on a distinguished road
Hi friends,
I'm simulating a tube with water flow.
The tube encounters boiling near the wall.
I intend to calculate 'void fraction versus enthalpy' along the channel.
Can you help me how to calculate void fraction?
I'm in an emergency condition.
Waiting for your comments!!!
Thanks Everybody
motahar is offline   Reply With Quote
Old   May 24, 2011, 23:04
oky
Oky Andytya
I want ask, how to get the value of convection coefficien [h] from Fluent directly ?
Thank you, regrads
OKY
Old   March 18, 2012, 14:11
Default Porous Jump
  #16
Akim Faisal
Akim679 is on a distinguished road
I am having problems with specifying the boundary condition of a bottom wall of a 3D rectangular channel as a "porous jump" . In GAMBIT I select Boundary type as "Porous Jump" however, when I import my mesh in FLUENT I receive an error stating that: "Cannot change porous to porous-jump because
there is only one adjacent cell thread". I am not sure what that means, can anyone please help me with this case. Any suggestion is appreciated.
Thanks,
Akim
Akim679 is offline   Reply With Quote
Old   September 8, 2012, 15:53
zaynah K.
zaynah04 is on a distinguished road
hi
had you been able to simulate your flow through porous??
if so please contact me..
zaynah
zaynah04 is offline   Reply With Quote
Old   March 6, 2013, 09:01
Leram is on a distinguished road
Originally Posted by Akim679 View Post
Thanks,
Akim
Hi Akim,
I am modelling a tube through which mixture of air and water passes and there is an air permeable membrane around the internal wall of the tube which is permeable to air only. I should model this as VOF in Fluent.
First, I need to set this wall boundary as Porous Jump in Gambit. I did the following steps in Gambit and when importing the mesh into Fluent, I got the same Error Message as you got: "Cannot change porous to porous-jump because there is only one adjacent cell thread".
1) created a cylinder as volume
2) meshed it
3) set the boundaries as inflow, outflow, and porous jump (for the volume)
4) set the fluid zone
5) export the mesh to Fluent
I was wondering if you could get rid of this Error Messsage and how?
Or if any body else can help me model this case, it is much appriciated!
Thanks,
Leram
Leram is offline   Reply With Quote
Old   May 15, 2013, 10:36
hadi
hadi.iraji is on a distinguished road
http://aerojet.engr.ucdavis.edu/fluenthelp/tutfiles/
hadi.iraji is offline   Reply With Quote
Old   August 21, 2013, 16:17
Default Porous media modeling
  #20
i man
chocolater is on a distinguished road
What is the most suitable software to simulat a porous media(some thing like flow past a fabric) and pressure drops?
CFX or Fluent?
Mohammed Alomari likes this.
chocolater is offline   Reply With Quote
gambit, porous
modeling the fluid flow in porous media by Fluent Mohsen Nazari FLUENT 5 April 26, 2019 04:45
Modeling heat transfer through a porous media harimighty FLUENT 3 July 23, 2016 05:11
Discrete phase modeling on porous media magnounibo FLUENT 0 April 9, 2009 08:18
Modeling thin perforated plates as porous media Mike FLUENT 0 August 21, 2007 04:16
porous media: Fluent or Star-CD? Igor Main CFD Forum 0 December 5, 2002 15:16
