October 16, 2019, 11:34 |
File Error in Fluent after Autosaving
Breanna
Rep Power: 6 |
Whenever a model I am running saves, I get the following error: Unable to open file. The file successfully saves (both cas and dat) but this occurs every time and the model stops running. I checked that the directory and autosave location is correct, as I thought that might be the issue. I have checked and I have enough disk space, and permission to write and read files in the directory I am saving to. I have tested the case on another computer and had the same issue, so it seems to be something with the files themselves rather than the computer. I am able to run other cases with autosave fine on this OS. I have tried reinstalling ANSYS and the error remains. If I do not close out ANSYS I get a second error: mpt_accept: error: accept failed: Permission denied MPI Application rank 0 exited before MPI_Finalize() with status 2 I am wondering if this has anything to do with the file name in the autosave tab? I am loading a file and the case has autosaved with -3 at the end of the original name (ex: IW_breaking_cont_slope_800m_4deg_slope_flat_bottom _slow-3.cas) When I am loading this file in it autosaves as IW_breaking_cont_slope_800m_4deg_slope_flat_bottom _slow-4 just fine. But when trying to open the file to continue after the first autosave is when I run into the error. I'd appreciate any assistance in solving this. |
Custom Thermophysical Properties | wsmith02 | OpenFOAM | 4 | June 1, 2023 14:30 |
Using PengRobinsonGas EoS with sprayFoam | Jabo | OpenFOAM Running, Solving & CFD | 35 | April 29, 2022 15:35 |
OpenFoam "Permission denied" and "command not found" problems. | iyidaniel@yahoo.co.uk | OpenFOAM Running, Solving & CFD | 11 | January 2, 2018 06:47 |
polynomial BC | srv537 | OpenFOAM Pre-Processing | 4 | December 3, 2016 09:07 |
what is swap4foam ?? | AB08 | OpenFOAM | 28 | February 2, 2016 01:22 |
