Why can't I remove the refined cells in my mesh?(can't coarse it |
October 22, 2019, 02:45 |
Rep Power: 8 |
Guys,
I refined my mesh using adaption option (> region adaption) but now cannot remove it. Why? I tried using the method mentioned in this post: Coarsening mesh in Fluent |
October 22, 2019, 11:09 |
Lucky
Rep Power: 66 |
Coarsening works the same way as refinement but there isn't anything like an undo button. You cannot simply undo your refinement. You have to mark the cells using a register the same way to do the refinement/coarsening each time and it modifies the mesh each time.
November 9, 2019, 09:14 |
#3 | |
Rep Power: 8 |
but I don't know why coarsening doesn't work for me. |
[snappyHexMesh] Number of cells in mesh don't match with size of cellLevel | colinB | OpenFOAM Meshing & Mesh Conversion | 14 | December 12, 2018 08:07 |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 08:54 |
[snappyHexMesh] snappyHexMesh Segmentation Fault | avd28 | OpenFOAM Meshing & Mesh Conversion | 11 | May 11, 2015 20:32 |
[snappyHexMesh] snappyHexMesh aborting | Tobi | OpenFOAM Meshing & Mesh Conversion | 0 | November 10, 2010 03:23 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 19:43 |
