a small particle going beyond wall while using 6DOF properties. Can I reflect it?
Old   December 21, 2022, 09:26
Default a small particle going beyond wall while using 6DOF properties. Can I reflect it?
Shouvik Mondal
shouvik is on a distinguished road
There is a particle which is moving under airflow inside a pipe. I am studying the 2D case using ANSYS Fluent. Also using overset mesh for the particle to place it inside the pipe.
While using 6 DOF properties under gravity, the particle moves out through the bottom wall where it was supposed to stop/bounce back/reflect. I am using one DOF translation in X axis and negative Y axis.
The animation video is shared in the below link:
https://drive.google.com/file/d/1YfE...ew?usp=sharing
Can anyone help me with this problem?
I can share the case file is needed.
shouvik is offline   Reply With Quote
6dof solver, dynamic mesh zones, fluent - udf
particle and channel wall interactions Achini Fluent UDF and Scheme Programming 13 April 25, 2022 18:50
particles leave domain Steffen595 CFX 9 March 7, 2016 16:19
Check particle impaction with User Fortran Julian K. CFX 3 January 12, 2012 09:46
[ICEM] Export ICEM mesh to Gambit / Fluent romekr ANSYS Meshing & Geometry 1 November 26, 2011 12:11
Multicomponent fluid Andrea CFX 2 October 11, 2004 05:12
