[Sponsors] | |||||
marko seggio
Rep Power: 8 ![]() |
Hi, i'm new in this forum. I have a problem with the sweep-method in Fluent. I have to realize a triangular section tube 2 meters in lenght, where I have a surface with constant heat flux from 1,35 meters where the tube begins. Posting the Geometry images. Cattura.jpg
2.PNG To realize the surface with constant heat flux I used new plane and slice functions. Now to realize the mesh I should use the sweep method and in Src/Trg selection I have to switch from "automatic" to "manual source" and the source should become Inlet, but selectioning the entire structure as body (i have two bodies indeed) I cannot do this operation. dsBuffer.bmp.jpg If someone could help me, that would be great |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| MPI problem with fluent | aryanet | FLUENT | 17 | October 30, 2017 22:04 |
| Problem with fluent mesh | edwardone333 | FLUENT | 0 | March 12, 2017 12:22 |
| Problem in using parallel process in fluent 14 | Tleja | FLUENT | 3 | September 13, 2013 11:54 |
| Problem of import fluent data to ilight fieldview | seasoul | FLUENT | 3 | September 9, 2008 23:36 |
| Rev: Can Fluent 6.0.20 predict this problem right? | Yazid Bindar | FLUENT | 5 | March 6, 2003 04:09 |
