Why doesn't my two-step chemical model work?[For H2+air reaction][finite rate model] |
November 9, 2019, 13:28 |
Rep Power: 8 |
Guys,
I'm trying to use the two-step chemical model in my simulation. Here is the chemical mechanism: Here is the reference of the mechanism: https://www.researchgate.net/publica...-O2_combustion I wrote this CHEMKIN file: Code:
ELEMENTS O H N END SPECIES OH H2 O2 H2O N2 END REACTIONS H2+O2<=>2OH 2.3E+22 0.000 10202 2OH+H2<=>2H2O 1.83E+27 0.000 21992 END I imported the CHEMKIN file and it's ok but the solution and the residuals doesn't look ok. See: As you see the residuals of OH and H2O have oscilation. It should be noted that the solution is ok for one-step Hydrogen-air mechanism of Fluent. What's the matter with this mechanism? What's your opinion? How to solve it? |
December 1, 2019, 09:28 |
Rep Power: 8 |
No idea??????
December 2, 2019, 01:01 |
Tamil Nadu
Rep Power: 6 |
Hi Sir ,
I want to clarify how do you calculate activation energy value from the reference file you attached and the values you entered in chemkin file looks different??? Looks forward for the reply Many Thanks Sowmiya |
December 2, 2019, 02:24 |
samm
Rep Power: 7 |
Check your units ,that may vary.
December 2, 2019, 08:30 |
#5 | |
Rep Power: 8 |
Thank you Sowmiya and Jegan for reply, Ok, let me tell you how I've written this CHEMKIN file. As it is said in this file (page No. 17): https://www.et.byu.edu/~tom/classes/...dentmanual.pdf The default units for A and activation energy are in terms of cm, sec, K, and moles. And also the Arrhenius equation is defined as(for CHEMKIN): https://www.researchgate.net/profile...image/ar-1.png As what is mentioned in the Article: https://www.researchgate.net/publica...-O2_combustion I attached a screenshot of the mechanism (table 1) that is mentioned in the article. http://uupload.ir/files/2ru4_dyfuhjklkk.png As you see in the screenshot, There are three parameters in the table; A, T, and n. I think that the authors of the paper didn't know that there are several forms of the Arrhenius equation. I attached the screenshots of three forms. Here are the images: https://www.researchgate.net/profile...image/ar-1.png https://www.researchgate.net/profile...image/ar-2.png https://www.researchgate.net/profile...image/ar-3.png Then I think the authors have made a mistake and the form of the Arrhenius equation for two-steps mechanism is this: https://www.researchgate.net/profile...image/ar-3.png Thus, T should be Tar. The unit of this parameter is K but for CHEMKIN file we need to convert it to cal/mole (convert Tar to Ea). Ok, Therfore we multiply Tar by the gas constant which is 1.98720425864083 (cal⋅K−1⋅mol−1). For example for the first reaction mechanism we have: 5134*1.98720425864083=10202 cal/mole For A, the units should be in terms of cm3, sec, and moles. Then we multiply A by 10e+6 to change the unit from m3.mol-1.s-1 to cm3.mol-1.s-1. Thus, e.g. we have: 2.3*10e+16*10e+6= 2.3*10e+22 This is the procedure that I've done to convert them. Do you see any problem? |
January 12, 2020, 01:40 |
Tamil Nadu
Rep Power: 6 |
Dear Sir,
Thank you for clarifying my doubts clearly. Also I want to know when you convert Ea in chemkin file to cal⋅K−1⋅mol−1 but the fluent should have the unit of Ea in J/ kgmol. How you are correlating the units? Looking forward for the reply. Many Thanks Sowmiya |
January 12, 2020, 02:50 |
samm
Rep Power: 7 |
Convert your cal/mol value into J/kmol
or in mechanism file we can write REACTIONS CAL/MOLE This may work |
[solidMechanics] Support thread for "Solid Mechanics Solvers added to OpenFOAM Extend" | bigphil | OpenFOAM CC Toolkits for Fluid-Structure Interaction | 686 | December 22, 2022 09:10 |
Air entrainment model setup for spillway | oajor | FLOW-3D | 4 | November 17, 2016 12:02 |
Star cd es-ice solver error | ernarasimman | STAR-CD | 2 | September 12, 2014 00:01 |
air bubble is disappear increasing time using vof | xujjun | CFX | 9 | June 9, 2009 07:59 |
error using combination of step function | xujjun | CFX | 1 | January 15, 2008 16:46 |
