January 20, 2020, 10:59 |
Unstable Stationary FLUENT
Claudio
Rep Power: 6 |
Hello everyone,
I am doing simulations on a closed domain. Reynolds number is in the transition region (around 2300) so I am using a laminar model with a fine mesh. The problem is that the stationary is unstable, and the values are oscilating around an average value. Due to the mesh, it is imposible to me to make a transient simulation, so I am asking if there is any way in FLUENT of getting the average value of the monitoring parameters. Also, I would like to know if it is possible to make a selective frequency damping in FLUENT, as I would like to add an extra term to Navier Stokes where the diference between to the calculated the velocity and the average velocity of the latest iterations is dumped by a factor. Thank you for your attention. |
January 21, 2020, 08:19 |
Andy
Rep Power: 8 |
The oscilation can have various reasons. 1. Your Mesh around inhection is too coarse. 2. What iteration scheme with what order are you using? Is there a pseudo time step, or cfl numer? Then it might be too small. 3. Also the fact that you are around transition-Re makes me suspicious too. I'm not sure if a laminar model can handle this operational point well. But I do not see your geometry. I would try to vary the cell size around the inlet boundaries. For this extra Termin, I would like to put your attention on the under relaxation numbers in the gui. Maybe they are enough for your purpose. |
January 21, 2020, 08:33 |
#3 | |
Claudio
Rep Power: 6 |
1. My actual mesh is of 15 Million elements, I supposed it is fine enough, nevertheless, I have to other finer meshes in case of necessity. 2. I am using a Coupled scheme with CFL of 20. For pressure I´m ussing PRESTO! (as it is a mixed convection problem) and for the other variables I am using a second order discretization. Under relaxation numbers are 0.5 for velocity, pressure, density and temperature. 3. It is a rectangular duct with a bent in the middle, U-shaped. |
Two questions on Fluent UDF | Steven | Fluent UDF and Scheme Programming | 7 | March 23, 2018 03:22 |
heat transfer with RANS wall function, over a flat plate (validation with fluent) | bruce | OpenFOAM Running, Solving & CFD | 6 | January 20, 2017 06:22 |
batch mode fluent - beginner | CompIng | FLUENT | 1 | November 30, 2015 11:48 |
Running UDF with Supercomputer | roi247 | FLUENT | 4 | October 15, 2015 13:41 |
Fluent 12.0 is worst then Fluent 6.2 | herntan | FLUENT | 5 | December 14, 2009 02:57 |
