February 6, 2020, 00:10 |
[Help] Use Unsteady State Statitics results
I have issues using the unsteady state statistics in the post processing. In my simulation i do have 49s out of 90s sampled with data sampling and I can create the curve I'd like through the tree on the left > Result > Plot > Plot Xy as it can be seen in the image. However when i enter the post processing software, this possibility to use the data from the average isn't shown, i've produced an image of all the data I can use to create curves. I do not know why but it seems that the unsteady state statistics in post processing is unavailable to me and I was wondering whether there was a box I could check to make this available in the options or anything really. At the moment I'm using Ansys version 19 R2 with a working student license. Much thanks if you have any idea of what I could do. |
February 6, 2020, 04:06 |
May or may not be
The post-processing tool is not really meant for Fluent; it was originally post-processor of CFX. So, it does not load everything from Fluent by default. What you can do although is to write CFD-Post compatible file and select the Unsteady Statistics in the available data. This is doable using File > Export > Solution Data. Select CFD-Post Compatible and in the last column, select all the variables you need, specifically Unsteady ones.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
February 10, 2020, 03:40 |
I wanted to thank you because doing this allowed me to access the data I needed. So thank you Fiomana |
February 10, 2020, 04:14 |
Good
Nice to know that the suggestions helped.
Ansys CFX problem: unexpected very high temperatures in premix laminar combustion | faizan_habib7 | CFX | 4 | February 1, 2016 17:00 |
is there any Differnce between results of Steady state and unsteady state | sreenivas | FLUENT | 0 | February 20, 2012 10:13 |
how to map results from steady state run to tranient case? | phsieh2005 | OpenFOAM Running, Solving & CFD | 2 | November 7, 2010 06:20 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 08:56 |
using steady state results for unsteady flow | siva appanna | Main CFD Forum | 3 | February 20, 2006 05:29 |
