March 10, 2020, 02:11 |
Pressure loss
reza
Rep Power: 6 |
when I run a simulation in fluent as a two-phase flow (Eulerian method) in a pipe, one phase is fluid and another is granular, the pressure loss is at least 6 times of the simulation in situation one phase flow with the same physical properties can anybody guide me? thanks |
March 10, 2020, 07:54 |
Pressure drop in granular phase
It would be difficult to comment on the value of pressure increase, however, pressure increase is the expected outcome. Adding a granular material or even the same material to an already existing flow will always increase the pressure drop. The amount of increase depends on various aspects. Granular flow can increase pressure drop drastically depending upon its inter-particle forces and turbulence generated.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
Pressure drop across a converging nozzle | mjkey | CFX | 16 | July 17, 2019 13:22 |
Outlet pressure | aja1345 | FLUENT | 5 | August 18, 2015 11:02 |
CFX-Post: How to calculate pressure loss for Airfoil? | safe.payi | CFX | 1 | April 14, 2014 15:02 |
Total pressure loss | Shljuki | CFX | 9 | June 13, 2013 07:41 |
Hydrostatic pressure in 2-phase flow modeling (long) | DS & HB | Main CFD Forum | 0 | January 8, 2000 15:00 |
