defining fluid flow in a packed bed of spheres
Old   March 17, 2020, 13:40
Default defining fluid flow in a packed bed of spheres
nithin rogan
rogan nithin is on a distinguished road
so, I've created a geometry in solidworks containing a number of spherical basll(fuel elements). the purpose of this model is to act as a heat storage system. the solving mode on fluent would be solidification-melting.
think of it like tennis balls filled in a bucket. fluid(water) is supposed to flow in between and contact every spherical body for ease of fluid flow, I have modelled the balls with gap of 1mm.though the tet mesh is generated without any issues,i am finding it hard to define the fluid flow domain. I tried creating a Boolean element(cylinder) and subtracting the balls to create the flow domain. but alas! as much a I tried, I keep failing to define flow domai. please, any help to define this fluid flow domain would be much appreciated .thanks in advance!... please find the link for the geometry here:
https://drive.google.com/file/d/1lmU...ew?ts=5e711598
rogan nithin is offline   Reply With Quote
Old   March 17, 2020, 13:46
Default Clarity
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
Your statements are slightly ambiguous. First, you have mentioned solidification and melting along with heat storage system; pointing towards PCMs. Later on you mention about water flow through packed bed and issues with meshing and domain creation. Do note that the domain is created before the meshing is done. It can be done later but that's not the usual way. Could you clarify
1. What is the objective of the simulation?
2. What issue are you facing currently? If it is related to Meshing and domain creation, I'd recommend posting it in relevant forum.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   March 17, 2020, 14:04
nithin rogan
Hi, thanks for the spontaneous response and sorry if my description was not clear
(1) yes, you are right. The purpose of this simulation is to check the outlet temperature of a pcm based packed bed latent heat storage system
(2) the issue that i am facing currently occurs whilst trying to create a boolean and subtract the spherical balls from a cylindrical enclosure(for fluid flow). The boolean simply fails to create and the balls are not subtracted from the enclosure.
Asked the same question here.:
https://studentcommunity.ansys.com/t...ostbadges=true
Problem similar to(but my geometry is much complex, i have even give the file's drive link up above in the main question):
https://studentcommunity.ansys.com/t...ed-of-spheres/
Old   March 17, 2020, 14:16
nithin rogan
*few clarifications: gap is 0.1mm and i am able to mesh it without issues..i simply want to define fluid flow domain..eithet by creating boolean and subtracting or by any other method
Old   March 17, 2020, 14:39
Default CAD Issue
vinerm's Avatar
Vinerm
This appears to be a CAD issue. Please post it in CAD related forum.
Regards,
Vinerm
flow domain, fluent, mesh
CFD analaysis of Pelton turbine amodpanthee CFX 31 April 19, 2018 18:02
Want Impeller Driven Fluid Flow: What Inlet and Outlet BC to use for Centrifugal Pump Zev Xavier FLUENT 3 May 9, 2016 06:42
two fluid, volumetric/mass flow rate at different volume fractions Veronique Pe CFX 2 November 26, 2014 05:30
Overflow Error in Multiphase Modelling with Two Continuous Fluids ashtonJ CFX 6 August 11, 2014 14:32
Gas Liquid flow in a packed column Rakib FLUENT 8 June 18, 2002 01:58
