Contour is not showing on the right surface!!! |
July 18, 2022, 09:46 |
Rep Power: 3 |
Hi all,
I have a cylinder pipe where the flow is in the z-direction. I wanted to see the species' concentration in the porous wall. Therefore, I created a plane using 3 points method, and I checked the yz plane was placed correctly (that only covered the wall portion). However, when I used the contour, it showed up as a complete yz plane at x=0. Does anyone how to fix this? Thanks in advance! |
July 18, 2022, 11:04 |
Problem is solved!
Rep Power: 3 |
I used isosurface and it worked now!
[snappyHexMesh] Surface layers do not merge | mc6421 | OpenFOAM Meshing & Mesh Conversion | 3 | December 5, 2023 03:00 |
Error when creating a contour on a user surface | NickiP | CFX | 2 | November 8, 2018 11:13 |
[Gmsh] Problem with Gmsh | nishant_hull | OpenFOAM Meshing & Mesh Conversion | 23 | August 5, 2015 02:09 |
[snappyHexMesh] Problem with Sanpper, surface still Rough | Zephiro88 | OpenFOAM Meshing & Mesh Conversion | 7 | November 5, 2014 12:05 |
how to create contour surface for some range | sa | CFX | 6 | January 28, 2009 14:36 |
