Unsteady Wall Statistics
Old   March 20, 2020, 11:40
Default Unsteady Wall Statistics
Cpt. Convergence
Captain Convergence is on a distinguished road
Hi all, I have lost 6 days of simulation in a cluster because Fluent didnīt collect statistics for my wall shear stresses.
As you can observe in the attached images I have selected the options to collect statistics for wall statistics but when I check my contours of Mean X-Wall Shear Stress, my values are 0, meaning that it didnīt collect any statistical data. It is not an inviscid case, check the other image where I have values for the instantaneous x-wall shear. However, I have data for the Mean Pressure Coefficient, which is inside wall statistics.
I am very confused with this, why isnīt fluent collecting statistics of my wall shear stresses??
Captain Convergence is offline   Reply With Quote
Old   March 20, 2020, 12:09
Default Wall Statistics
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
Though it should get interpolated, but did you try disabling Node and Global values while plotting mean x-shear stress?
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   March 20, 2020, 13:27
Cpt. Convergence
Since it is a transient simulation, the simulation needs to be run for a while in order to collect data for having sufficient data in order to generate averaged quantities. There isnīt any interpolation here.
Old   March 20, 2020, 15:24
Default Interpolation
vinerm's Avatar
Vinerm
Running for at least a couple of time steps is obvious requirement. But that you've already done; you ran it for six days. But while plotting contours, you have Node values as well as Global scale selected. These should not cause any issues as such because although the sampling is done at centers of the cells yet data interpolation is done for the nodes. But sometimes, some of the variables are 0 on the walls. Stress should not be zero but there's no harm in checking if the actual values are also 0 or not. That's why I suggested you to plot contours with Node values and Global scale deselected.
Regards,
Vinerm
Natural convection in a closed domain STILL NEEDING help! Yr0gErG FLUENT 4 December 2, 2019 01:04
[blockMesh] mergePatchPairs reducing a face to less than 3 points aow OpenFOAM Meshing & Mesh Conversion 2 June 1, 2018 18:37
Enhanced Wall Treatment paduchev FLUENT 24 January 8, 2018 12:55
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
Forces on wall in unsteady case sondinho FLUENT 4 December 8, 2012 08:55
