How the power input is estimated in savonius turbine in 2D simulation? |
March 23, 2020, 19:39 |
Naveen
Rep Power: 7 |
I am trying to simulate the 2D model of savonius turbine. The power input to the system is proportional to the projected area. For 2D dynamic simulation, how much moment of inertia, I need to provide for a 2D model. Theorotically, at a diameter of 1.5m, total input power is 76.25 N-m per sq.meter at 5m/s inlet velocity. How to model this in a planar 2D simulation? My total turbine weight is 100Kg.
March 24, 2020, 02:56 |
Power
For a turbine, it has to be output and not input. Input is in terms of momentum or kinetic energy of the flow driving the turbine.
In a 2D planar system, Fluent assumes that the dimension is 1 m in z-direction. From your post, it is not very clear what you wish to achieve from the simulation.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
Calculating the Cp (Power Coefficient ) for a cross flow vertical wind turbine | AS_Aero | CFX | 13 | February 14, 2018 16:57 |
Vertical axis water turbine simulation | SHIKHA BHUYAN | ANSYS | 0 | September 16, 2014 01:06 |
Vertical axis water turbine simulation | SHIKHA BHUYAN | CFX | 1 | September 15, 2014 07:40 |
shaft power versus RMP curve in wind turbine simulation | zhenduan306 | CFX | 28 | November 8, 2012 10:11 |
Need help on calculation of power coefficient for contra-rotating turbine | altomos | CFX | 5 | October 7, 2012 06:26 |
