February 26, 2022, 11:45 |
Solution animation disappeared
Garrett
Hi. I attempted to save a solution animation as a video file and the software was not responding/ crashed. As a result, the "solution" window closed and I got bumped back to the main screen. Next to the solution tab there was now a checkmark and a pause sign. When I re-opened the solution window and tried to view the animation I had before, it was empty/not recorded. Is there any way to recover this animation? This has happened to me several times and it's extremely frustrating after the code was computing for hours.
February 28, 2022, 09:57 |
#2 | |
Void_CFD-user
Rep Power: 4 |
Although if you stored your solution files at every time step during you solve, you can view animations in CFD post. |
March 3, 2022, 07:52 |
Alexander
Rep Power: 34 |
as far as I know, recovering is not possible
personally I'm making pictures through simulation, so I can make animation later. Some data will be available even if the fluent has crashed
best regards ****************************** press LIKE if this message was helpful |
Solution in animation in Tee fitting | zeeshan2k6 | Main CFD Forum | 0 | January 2, 2018 06:31 |
grid dependancy | gueynard a. | Main CFD Forum | 19 | June 27, 2014 21:22 |
Steady State Solution animation | rmageddon | FLUENT | 1 | April 19, 2014 00:38 |
Naca 0012 (compressible and inviscid) flow convergence problem | bipulsaha | FLUENT | 1 | July 6, 2011 07:51 |
Wall functions | Abhijit Tilak | Main CFD Forum | 6 | February 5, 1999 01:16 |
