Solution animation disappeared
Old   February 26, 2022, 11:45
Angry Solution animation disappeared
Garrett
garrettc is on a distinguished road
Hi. I attempted to save a solution animation as a video file and the software was not responding/ crashed. As a result, the "solution" window closed and I got bumped back to the main screen. Next to the solution tab there was now a checkmark and a pause sign. When I re-opened the solution window and tried to view the animation I had before, it was empty/not recorded. Is there any way to recover this animation? This has happened to me several times and it's extremely frustrating after the code was computing for hours.
garrettc is offline   Reply With Quote
Old   February 28, 2022, 09:57
Void_CFD-user
Indra is on a distinguished road
When you create a solution animation, you should store it as hsf file rather than in memory. The in memory animation disappears after the fluent session has been closed. But if your fluent session crashed, it might have deleted all the animation. There's not really a way to recover animation if you don't have you animation stored as a hsf file.
Although if you stored your solution files at every time step during you solve, you can view animations in CFD post.
Indra is offline   Reply With Quote
Old   March 3, 2022, 07:52
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
as far as I know, recovering is not possible
personally I'm making pictures through simulation, so I can make animation later.
Some data will be available even if the fluent has crashed
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Solution in animation in Tee fitting zeeshan2k6 Main CFD Forum 0 January 2, 2018 06:31
grid dependancy gueynard a. Main CFD Forum 19 June 27, 2014 21:22
Steady State Solution animation rmageddon FLUENT 1 April 19, 2014 00:38
Naca 0012 (compressible and inviscid) flow convergence problem bipulsaha FLUENT 1 July 6, 2011 07:51
Wall functions Abhijit Tilak Main CFD Forum 6 February 5, 1999 01:16
