Lolita
Rep Power: 9 ![]() |
hello
I am simulating a two-phase air-water flow using the VOF method. It's a very simple problem, air bubble rising up under buoyancy force. For Dynamic meshing, I am using Adaption by Gradient, where I am using this setting Grad_adaption.jpg, with this setting I am getting this refined at middle.PNG, but what I want is this octree.jpg. Any help would be highly appreciated regards |
You may be using wrong values for the threshold. Do note that volume fraction is bounded between 0 and 1 but not its gradient. You should first plot the gradient contours and then check the values around the bubble. Within a particular phase, gradient is always 0, so, around the bubble it would have some value. But if you use very small value, then it would refine most of the domain.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
Problem with 'Mapped Face Meshing' | RobertW | FLUENT | 0 | November 19, 2016 15:39 |
[ICEM] ICEM 3d meshing problem | Eng.Mahmoud abd elsalam | ANSYS Meshing & Geometry | 0 | June 24, 2016 23:16 |
Learning Dynamic Meshing | SKDinfinity | Fluent UDF and Scheme Programming | 2 | June 11, 2016 06:43 |
Problem in 2D dynamic meshing | engrmansoor2534 | FLUENT | 0 | April 4, 2016 02:36 |
[Gmsh] Vertex numbering is dense | KateEisenhower | OpenFOAM Meshing & Mesh Conversion | 7 | August 3, 2015 10:49 |
