April 10, 2020, 13:18 |
seperation of drag forces
Rep Power: 6 |
hi,
i have run a multiphase VOF simulation of a body part submerged in water and part in air, is there a way in which i can seperate from the drag results how much is from air and how much is from water? I am currently using the density of the water as my reference value also, thanks in advance |
April 10, 2020, 14:24 |
Separation
If you want to determine drag at a particular instant of time, then you can mark the cells with volume fraction of either liquid or gas and then use this register to separate the face into two; one will automatically be adjacent to liquid and the other to gas. Then you can report separate forces and coefficients. However, if this is to be done continuously in a transient case, then you cannot separate the face because the interface won't be fixed. The only way would be to use UDF then. Or you can use a custom field function to determine shear stress and pressure and then use those to calculate forces.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
drag force, fluent, multiphase, transient, vof |
The CoP Does not exist: Validating Aerodynamic forces through a "line of action" | ds4719 | Main CFD Forum | 14 | February 18, 2022 18:05 |
Residuals and forces spiraling out of control before failing | edomalley1 | OpenFOAM Running, Solving & CFD | 3 | September 7, 2018 10:42 |
PimpleFoam - oscillating forces and drag coefficient | crizpi21 | OpenFOAM Running, Solving & CFD | 3 | July 2, 2018 11:53 |
Negative drag forces of fanwing airfoil | vkid185 | OpenFOAM Post-Processing | 0 | March 26, 2017 07:16 |
How to write the drag forces and separate it into viscosity drag and pressure drag | Joanna Huang | OpenFOAM Post-Processing | 0 | January 7, 2013 11:37 |
