April 22, 2020, 10:45 |
UDF for heat flux boundary condition
Francesco
Rep Power: 6 |
Hi everybody
I'm new to c language, i'm writing this udf to have this specific heatflux profile, depending on the temperature of the wall. It has to be updated each time-step also, since temperature at the wall is changing during time. After solving some syntax errors now i have the following error in the ansys console: c(23): error C2064: term does not evaluate to a function taking 337 arguments Code:
#include "udf.h" DEFINE_PROFILE(wallheatflux,t,i) { face_t f; real temp; temp = F_T(f,t); real cp1=4180; real cp2=3488.3; real Tsat=373; real Tliq=293; real Ql=2257000; real flow_time = RP_Get_Real("flow-time"); begin_f_loop (f,t) { if(temp>373) F_PROFILE(f,t,i) = -1.2099*(cp1*(Tsat-Tliq)+Ql+cp2*(temp-Tsat)); elseif(temp<=373) F_PROFILE(f,t,i) = -1.2099*(cp1*(temp-Tliq)); } end_f_loop (f,t) } Thank you in advance! |
April 22, 2020, 10:51 |
Two thing
f does not exist outside f_loop. Fluent provides its value only within the loop. Hence, F_T has to be inside the loop. That's the bug. Secondly, do not use RP_ call. This is expensive in terms of time and should be used only if really needed. Use CURRENT_TIME; this is C variable defined within Fluent and is equal to current time.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
April 22, 2020, 12:36 |
Francesco
Rep Power: 6 |
I modified it in this way, but the error is the same.
#include "udf.h" DEFINE_PROFILE(wallheatflux,t,i) { face_t f; real cp1=4180; real cp2=3488.3; real Tsat=373; real Tliq=293; real Ql=2257000; real time = CURRENT_TIME; begin_f_loop (f,t) { real temp = F_T(f,t); if(temp>373) F_PROFILE(f,t,i) = -1.2099*(cp1*(Tsat-Tliq)+Ql+cp2*(temp-Tsat)); elseif(temp<=373) F_PROFILE(f,t,i) = -1.2099*(cp1*(temp-Tliq)); } end_f_loop (f,t) } |
April 22, 2020, 12:59 |
Try this
Try to compile or interpret the attached file
April 22, 2020, 13:30 |
Francesco
Rep Power: 6 |
Where do you write the codes? Which programme is this?
The code compile very well, you solve my problem again vinerm. Thank you a lot! |
April 22, 2020, 13:35 |
Editor
You can use any editor. I use vi but it does not really matter as long as you save it in a proper format. If you use Windows, prefer using textpad or notepad++.
Centrifugal fan | j0hnny | CFX | 13 | October 1, 2019 13:55 |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 07:30 |
UDF for a time varying heat flux boundary condition | B.Hamada | Fluent UDF and Scheme Programming | 9 | August 8, 2018 12:51 |
Waterwheel shaped turbine inside a pipe simulation problem | mshahed91 | CFX | 3 | January 10, 2015 11:19 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 07:00 |
