May 12, 2020, 12:43 |
Chaning wall to interior
Rep Power: 6 |
Hello everyone,
I divided a 2D domain into parts in geometry section to make a structured mesh. (Divided fluid domain into 3 by line) However, in fluent some parts were defined as Wall, even though the lines are inside the domains. It should be a part of the fluid domain. I was just wondering what are the consequences of changing wall to interior? Also the walls are ended up creating new cell zone. Can I turn these walls into interior? |
May 12, 2020, 13:25 |
Wall to Interior
If it shows as wall-shadow pairs, then you can directly change Type to Interior. If not, then you can use Mesh > Fuse provided the mesh on both sides is same within a certain tolerance. Otherwise, you have to go back to CAD, ensure that all bodies belong to same part, and then remesh it. Another alternative is to convert these into interfaces and then create Mesh Interface.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
Converting wall into interior | kennyboy | FLUENT | 3 | June 29, 2017 02:32 |
[mesh manipulation] mergeMeshes problem | Attesz | OpenFOAM Meshing & Mesh Conversion | 3 | July 29, 2015 04:15 |
[Commercial meshers] tmerge utility creates unwanted interface/walls comes in the final mesh | Shoonya | OpenFOAM Meshing & Mesh Conversion | 11 | January 20, 2012 06:23 |
wall..interior..interface | mumdad | FLUENT | 1 | June 6, 2008 05:50 |
