Normal and Shear Stress
Old   May 21, 2020, 17:17
Default Normal and Shear Stress
CWL
cwl6750084 is on a distinguished road
I am calculating a fluid flow in a CD nozzle. Fluent computes a quantity "wall shear stress", which I assume is the black arrow in the attached figure. How do I compute the normal stress from Fluent? I do not see it anywhere in the dropdown manuals, neither seeing it in the Help/Manual. Does anyone have any ideas on this? I have been struggling with this for a week now.
Thanks for any comments on this.
cwl6750084 is offline   Reply With Quote
Old   May 22, 2020, 02:55
Default Normal Stress
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
Actually, you know it and everybody knows it. The only difference is that the fluids community does not usually use the term normal stress to define it, we prefer to call it pressure.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   May 24, 2020, 21:52
CWL
Thanks for your answer. Just want to make sure, I always thought that pressure is normal to the bulk flow direction, yet the normal stress must be perpendicular normal to the wall surface locally. Are the two the same?
Old   May 25, 2020, 10:42
Default Pressure
vinerm's Avatar
Vinerm
Pressure is always normal to each boundary. If there is an angle, then it implies shear stress.
Regards,
Vinerm
Old   May 25, 2020, 10:58
CWL
Thanks for that. So, if pressure given by Fluent (assuming the one at the node right next to the wall) is the normal stress (the red arrow in the original figure), which angle is the one you mentioned. (Sorry that I am not very good in mechanics.)
Old   May 25, 2020, 11:33
Default Angle
vinerm's Avatar
Vinerm
A force vector acting on a solid object can always be resolved into normal and tangential components. It is possible that whole of the vector is normal to the wall or it has an angle other than 90. In the latter case, there will be some shear stress due to the tangential component, while the normal component would be called pressure.
Regards,
Vinerm
Measuring Normal Stress and Shear stress AS_Aero STAR-CCM+ 1 December 7, 2017 12:51
Fluid wall shear stress Sinead Kelly (Kelly) OpenFOAM Running, Solving & CFD 2 March 30, 2011 06:41
reynolds normal and shear stress components saran Siemens 0 August 28, 2006 00:54
Plot normal and shear stress sagga FLUENT 2 July 15, 2005 00:46
Shear and normal stress on a boundary Fing CFX 2 May 27, 2004 01:47
