how to input an experimental data of rotational deformation as a UDF?
Like Tree1Likes
  • 1 Post By vinerm
Old   May 28, 2020, 08:24
Default how to input an experimental data of rotational deformation as a UDF?
Ki Jong Kim
denis Kim is on a distinguished road
Hi everyone.
i had rotational test data(angular displacement).
For exact comparison of experiment and simulation(Fluent),
i want to apply directly the experimental data to Fluent using UDF.
Anyone who have experience or know how to deal with it,
please help me...
I really appreciate it in advance!
denis Kim is offline   Reply With Quote
Old   May 28, 2020, 09:38
Default Data
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
Is it angular displacement or angular deformation? Both are different. And you don't need a UDF for this.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   May 28, 2020, 11:52
Default data; angular displacement
Ki Jong Kim
very thank you for yr quick reply!
i have a angular displacement from the encoder in the experiment, not deformation(typo!!).
No need for UDF???
i want to make a rotation of a cylindrical structure using the initial angular displacement from the experiment. So, UDF should be needed i think.
i hope hearing from you soon.
Old   May 28, 2020, 12:11
Default Profile
vinerm's Avatar
Vinerm
UDF is not required. You can use Profile file. The type of profile depends on the type of motion. If the cylinder is rotating about its own axis, then a simple transient profile will suffice.
denis Kim likes this.
Regards,
Vinerm
Old   May 28, 2020, 12:34
Default Angular profile
Ki Jong Kim
Thanks again for reply!
you right! Rotational motion with harmonic period is needed in the simulation!
Does profile means the "time-angle" data?
If right, and then if i make a format of angular profile to be inserted, can you
explain how to use it?
Best regards,
Kim
Old   May 28, 2020, 12:44
Default Transient Profile
vinerm's Avatar
Vinerm
You need to use transient profile. Look at the following
https://www.afs.enea.it/project/nept...ug/node225.htm
Do note that there is no option to provide displacement to Fluent. You have to convert it into speed and provide speed as profile.
Regards,
Vinerm
Old   August 6, 2020, 00:41
Default transient profile
Ki Jong Kim
it doesn't work...
anybody who can help me?
Please...
Old   August 6, 2020, 00:57
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
you should explain your problem if you want to get help
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   August 6, 2020, 03:35
Default Input of experimental data into analysis in Fluent
Ki Jong Kim
By using the profile (.prof), is it available to use the experiemntal rotational data into the analysis for same motion in the Fluent?
according to the venermn, velocity profile should be inputted, not rotational angle. but the result in the simulation is extremely larger than experimental data.
UDF: How to load data from an external file into a vector EmiS Fluent UDF and Scheme Programming 17 January 14, 2019 01:55
Using input parameters (velocity inlet) in UDFs - bad UDF? student_1994 Fluent UDF and Scheme Programming 6 September 14, 2018 20:31
Data Produced From Fine Marine Cant Match with The Experimental Data PeiSan Fidelity CFD 4 August 23, 2014 05:33
Experimental data validation and/or grid independence svp Main CFD Forum 5 June 6, 2014 03:24
How to input transient pressure data as BC in pre? User CFX 4 February 6, 2006 01:15
