June 15, 2020, 10:38 |
Heat of reaction
sara
Rep Power: 6 |
I am trying to model 3D, reacting case. I defined my fluids and their enthalpies also the kinetic model and Arrhenius constants. However the heat of reaction source in the result reports is zero. Does it means that I have exothermic reactions or there is a mistake? Thank you! |
June 15, 2020, 10:57 |
Heat of Reaction
It is calculated using standard state enthalpies provided by the user in the materials panel.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
June 15, 2020, 11:22 |
sara
Rep Power: 6 |
Thank you Vinerm for your reply.
I already defined standard state enthalpies as constant in the material panel, that makes me confused! |
June 15, 2020, 16:30 |
Standard State Enthalpies
Also check for their values. If the sum of the enthalpies, of course along with the moles of the products and reactants, is 0, then heat of reaction would be 0. So, values should be realistic. Try some random values and see if it changes anything. And it would not show up after initialization. Case has to be run, at least for 1 iteration.
Interphase mass transfer of a reaction | cfx_ws1992 | Main CFD Forum | 0 | May 15, 2017 21:42 |
UDF to access quantity of heat absorbed by one phase in Multi phase reaction process | Yuting | FLUENT | 0 | March 15, 2017 22:52 |
Error - Solar absorber - Solar Thermal Radiation | MichaelK | CFX | 12 | September 1, 2016 05:15 |
Reaction heat | Laci | FLUENT | 2 | July 23, 2009 02:03 |
heat of reaction | Paul | FLUENT | 4 | August 7, 2003 11:58 |
