yplus and mesh consideration
Old   March 25, 2021, 14:24
Default yplus and mesh consideration
sonsonst is on a distinguished road
Hi all,
I am facing which I consider the classical problem in CFD models. I am stuck with a mesh.
yplus consideration with k-w turbulence model requires values close to 1, which in my model means very small first layer height of 1e-5m (compare to hundreds of meters domain). Furthermore, my geometry is a cylinder disk which have very sharp angles around the edges (90 degrees). That, produces elements with very low orthogonal quality near the edge and, only increasing the number of elements in an enormous way makes my mesh suitable.
Any tip on this kind of simple geometries but rather difficult to mesh? I wonder if I am missing something here. Any thoughts would be much appreciated.
Thanks to all
sonsonst is offline   Reply With Quote
Old   March 31, 2021, 07:12
Just in case somebody else finds the same situation. Rounding sharp edges was the solution that helped me to overcome the situation.
Impeller mesh with Turbogrid and Yplus results Nabu CFX 4 September 5, 2022 19:00
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field lakeat OpenFOAM Community Contributions 58 December 23, 2021 02:36
Yplus value as an indicator of mesh convergence renos Main CFD Forum 2 April 28, 2020 19:49
problem to calculate yplus in moving mesh simin_ds OpenFOAM Post-Processing 0 January 29, 2015 10:43
Mesh adaption & yplus Aloise CFX 0 December 13, 2006 17:22
