UDF - C_UDMI is giving sigsegv error
Like Tree1Likes
  • 1 Post By AlexanderZ
Old   August 6, 2020, 01:56
Default UDF - C_UDMI is giving sigsegv error
Amir fit
fit78 is on a distinguished road
I am having issues with C-UDMI with my simple code.
I read all the thread relevant to this but to no avail.
I am using Ansys 2019 R2
- I have allocated a memory in UDM GUI
-The UDF worked fine without C_UDMI.
Anyone can assist?
TQ
Fit78
/* UDF to define a simple mass transfer
The "to" phase is the gas phase and the "from" phase is the liquid phase */
#include "udf.h"
DEFINE_MASS_TRANSFER(liq_gas_source, cell, thread, from_index,from_species_index, to_index, to_species_index)
cell_t c;
Thread *t;
real m_vap,m_air;
real W_I;
real vof_cutoff = 0.05;
real tmr,vmr,amr,vpp;
real P_pvi;
real Diff;
real m_dot, dp, m_source;
Thread *gas = THREAD_SUB_THREAD(thread, to_index);
Thread *liq = THREAD_SUB_THREAD(thread, from_index);
real press = C_P(cell, thread);
real rho_l = C_R(cell,liq);
real rho_v = C_R(cell,gas);
real vof_l = C_VOF(cell,liq);
real vof_v = C_VOF(cell,gas);
m_dot = 0.;
m_vap=18.01528;
m_air=28.97;
//Mass diffusivity for air-water
Diff=0.282;
//total mole ratio - vapor mole ratio -air mole ratio
tmr=m_vap+m_air;
vmr=m_vap/tmr;
amr=m_air/tmr;
if ( (vof_l > vof_cutoff ) && (vof_l < (1 - vof_cutoff) ))
{ /* Evaporative cooling at interface */
//vapor partial pressure
vpp = (vmr/tmr)*press;
//mass fraction at interface
W_I=(m_vap*vpp)/((m_air*(press-vpp))+(m_vap*vpp));
//mass flow rate at interface - supposed to include dw/dr but later
m_dot=(rho_v*Diff)/(1-W_I);
// save mass flow rate to user defined memory in Fluent
C_UDMI(c,t,0) = m_dot;
return (m_dot);
fit78 is offline   Reply With Quote
Old   August 6, 2020, 02:01
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
use
C_UDMI(cell,thread,0) = m_dot;
fit78 likes this.
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   August 6, 2020, 02:17
Amir fit
Thanks! That did it. Saved me lots of time debugging. Sometimes you just need a fresh pair of eyes. I wonder why the syntax is very inconsistent like this.
Old   November 6, 2023, 01:49
anonymous96
anonymous96_ is on a distinguished road
Hi
I am trying to calculate volumetric flow rate through an interior surface.Following is my piece of code:
DEFINE_ON_DEMAND(ach_udf)
Thread *t,*to;
face_t f;
cell_t co;
Domain *d;
d = Get_Domain(1);
real A[ND_ND];
t = Lookup_Thread(d,2);
real ACHt_mean_out=0;
real ACHt_mean_in=0;
begin_f_loop(f,t)
F_AREA(A,f,t);
co = F_C0(f, t);
to = THREAD_T0(t);
real vel_roof= C_V(co,to);
if (vel_roof>0)
ACHt_mean_out += vel_roof*NV_MAG(A);
else
ACHt_mean_in +=vel_roof*NV_MAG(A);
end_f_loop(f,t)
This is getting compiled and solved properly. But as soon as I use C_UDMI for storage, it gives error on using execute on demand. Following is the code which gives error:
Thread *t,*to;
face_t f;
cell_t co;
Domain *d;
d = Get_Domain(1);
real A[ND_ND];
begin_f_loop(f,t)
F_AREA(A,f,t);
co = F_C0(f, t);
to = THREAD_T0(t);
if (vel_roof>0)
else
end_f_loop(f,t)
C_UDMI (co,to,0)=ACHt_mean_out ;
Can you please tell me what is wrong here.
anonymous96_ is offline   Reply With Quote
Old   November 6, 2023, 22:56
Alexander
allocate user defined memory
fluent gui-> user defined -> memory -> user defined memory location change to 1
best regards
Old   November 6, 2023, 23:05
anonymous96
I have already allocated the UDM in GUI.
Old   November 7, 2023, 00:14
Alexander
#include "udf.h"
Thread *t,*to;
face_t f;
cell_t co;
Domain *d;
real A[ND_ND];
real vel_roof;
d = Get_Domain(1);
begin_f_loop(f,t)
F_AREA(A,f,t);
co = F_C0(f, t);
to = THREAD_T0(t);
if (vel_roof>0)
else
end_f_loop(f,t)
best regards
Old   November 7, 2023, 00:41
anonymous96
I have included the header files too just not posted them here. As I said , the code runs successfully without adding C_UDMI(co, to,0)=........., but as soon as I add this to the code, it gives error on using "execute" for execute on demand.
c_udmi, fluent, udf
UDF for DPM particle deposition modelingpa haghshenasfard Fluent UDF and Scheme Programming 10 September 15, 2019 02:03
Undeclared Identifier Errof UDF SteveGoat Fluent UDF and Scheme Programming 7 October 15, 2014 07:11
ParaView for OF-1.6-ext Chrisi1984 OpenFOAM Installation 0 December 31, 2010 06:42
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 02:32
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
