August 8, 2020, 12:05 |
External gear pump-turbine
Me_1989
Rep Power: 5 |
Recently, I try to simulate an external gear pump which was used as a turbine. I try to use 1DOF rotation as a dynamic mesh for the motion of the gears ( there are two gears including driver and driven gears). I set one 1DOF for the driver and another 1DOF for the driven gears. I also define the angular velocity but unfortunately there is no motion in the preview! There is a warning which is "Warning: unable to read motion history file". I would be so grateful if anybody can give me any solution for this? Best regards |
defining angular velocity of an external gear pump | Me_1989 | Fluent UDF and Scheme Programming | 9 | August 8, 2020 20:05 |
Setting up 3D simulation for external gear pump | 310toumad | FLUENT | 2 | February 5, 2019 09:12 |
CGNS Compiling | Diego | Main CFD Forum | 17 | December 21, 2014 01:40 |
External Gear Pump | interawe | ANSYS Meshing & Geometry | 0 | April 14, 2009 17:55 |
3D External Gear Pump | Mustafa Ayad | FLUENT | 1 | January 26, 2009 09:55 |
