Drag Coefficient Convergence/Accuracy Problems
Old   May 26, 2020, 09:42
Exclamation Drag Coefficient Convergence/Accuracy Problems
cfdkktr is on a distinguished road
I am trying to get C_D vs Mach distribution for both finned and finless artillery projectiles with zero angle of attacks. The range for Mach number is from 0 to 4. I am trying to compute the C_D value for every Mach number with increment of ~0.1-0.25. However, I am experiencing quite significant convergence and/or accuracy problems for most of the cases. Although I done research and tried many different mesh and solution setup combinations, the problem is remaining the same.
For this kind of cases what do you suggest as a general technique?
What turbulence model should be implemented?
Which points should be considered as important while meshing? Is a different mesh for each Mach number a must? How to determine the correct y+ values? What geometric detail should be neglected during modelling?
What can be done to get solution converges faster in terms of both calculation time and number of iterations?
I would be very grateful for any help, thank you!
cfdkktr is offline   Reply With Quote
Old   May 27, 2020, 04:36
Default Mach number
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
For 0-4 Mach, there are three regimes and all required different settings.
1. 0-0.3 is incompressible regime and you can work with constant density fluid. Beyond that, fluid has to be compressible.
2. 0.3 - 1 is compressible but subsonic regime. Actually, 0.9 to 1.1 is considered transonic regime but this one does not really require anything special
3. 1 - 4 is supsersonic regime and would have shocks
As far as modeling is concerned, it has four regimes. Mach 1-2 can be worked with pressure based solver, but beyond that you need density based solver. You will also have to look at Re and the ratio of Ma and Re because that defines Kn. For low Re, laminar flow will work but may require transient simulation. For very high Re, you can work with Euler equations (inviscid). So, there is no single set of conditions that will work with all. You have to setup three to four regimes, each with separate type of mesh, material, boundary and operating conditions, as well as, physical and numerical models. You can use density based solver for all cases but that will be very time-consuming and difficult to converge. Similarly, you can use very fine mesh for all cases but would be an overkill for low Re and low Ma flows.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   August 19, 2020, 10:15
mahdi rostami
mahdi-united is on a distinguished road
hi my dear friend
thanks for all helps in past
in simulation of projectile motion, how to calculate Re number?
i need to set the one of the turbulent models and i don't know which one is appropriate
mach number is varied as 0.1 to 3 in my project
i read your post about different regimes and different setups in projectile motion.
mahdi-united is offline   Reply With Quote
ballistics, cfd, drag, fluent, projectile
Different Drag coefficient value??? recep911234 FLUENT 3 December 1, 2018 09:29
drag coefficient in ansys fluent 12.0 krishna FLUENT 19 April 12, 2018 00:49
Incorrect Drag and Drag Coefficient for flow over a cylinder ozzythewise Main CFD Forum 8 June 13, 2012 06:24
Post Processing Drag Coefficient squanto773 OpenFOAM Post-Processing 1 March 7, 2012 09:43
Automotive test case vinz OpenFOAM Running, Solving & CFD 98 October 27, 2008 08:43
