Fluid Direction Error
Old   September 3, 2020, 10:01
Default Fluid Direction Error
Raza Waseem
Raza5 is on a distinguished road
Hi Everyone,
I am simulating Airflow in the nozzle. I used the k-omega SST model for that but after passing the throat fluid direction is downward as shown in attached figure. How can I resolve this issue? I am using Ansys Fluent academic version 2020R1. Your response will be appreciated.
Thank you!
Raza5 is offline   Reply With Quote
Old   September 3, 2020, 11:19
eshimshi is on a distinguished road
The short answer.... you can't.
This a physical phenomena called Coanda effect, in which the flow attaches to the wall.
If you increase the width of your channel downstream of the throat it may solve the problem.
But you should know that in an experiment you might see the same phenomena.
eshimshi is offline   Reply With Quote
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 09:17
Compiling dynamicTopoFvMesh for OpenFOAM 2.1.x Saxwax OpenFOAM Installation 25 November 29, 2013 05:34
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 09:31
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
