Missing surface from fluent meshing to solver
Old   September 18, 2020, 22:51
Default Missing surface from fluent meshing to solver
johan.betancour is on a distinguished road
Hello everyone,
I have ANSYS 2019 R2 and I'm having problems using fluent with meshing mode and the watertight workflow, I need to report the torque generated on a rotor, for which I have created a named selection with all its walls in spaceclaim. as you can see inthe attached images.
Then, when I am updating the borders in the meshing workflow, I have noticed that the turbine does not appear in the selection by "label" but in the selection by "zone" (I don't know if it is related with my problem or it's normal)
Finally, when the mesh is generated and I switch to solution mode, I cannot find the turbine as a wall zone to generate the report of the moment from it.
Could anyone help me?
Thanks for your attention.
Best regards, Johan Betancour Osorio.
johan.betancour is offline   Reply With Quote
fluent, meshing, watertight, workflow
[Gmsh] gmshToFoam generates patches with 0 faces and 0 points Simurgh OpenFOAM Meshing & Mesh Conversion 4 August 25, 2023 07:58
How to couple transient thermal solver with fluent solver? sahil_chaddha FLUENT 0 February 21, 2019 09:14
[ANSYS Meshing] Help with element size sandri_92 ANSYS Meshing & Geometry 14 November 14, 2018 07:54
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
