Creating animation in fluent remote cluster using journal file
Old   October 28, 2020, 02:37
Default Creating animation in fluent remote cluster using journal file
soshere is on a distinguished road
I have created the animation by writing the following commands in my journal file (remote linux cluster):
/display/set/contours/filled-contours yes
/display/set/picture/driver png
/display/set/picture/landscape yes
/display/set/picture/x-resolution 960
/display/set/picture/y-resolution 720
/display/set/picture/color-mode color
/display/contour velocity-magnitude 0 1
/display/save-picture velmag%t.png
/solve/execute-commands/add-edit command-2 1 "time-step" "/display/contour velocity-magnitude 0 1"
/solve/execute-commands/add-edit command-3 1 "time-step" "/display/save-picture velmag%t.png"
/file/auto-save data-frequency 1
/file/auto-save append-file-name-with time-step 6
But the problem is that my domain is large while the area of interest (blades in my case VAWT Simulation) is very small so when the fluent saves the picture the actual area of interest (small portion of domain) is barely visible. My question is how can I alter the journal file code in order to zoom to the area of interest?
P.S: See sample picture attached and u would notice that area of interest is barely visible.
soshere is offline   Reply With Quote
how to calculate mass flow rate on patches and summation of that during the run? immortality OpenFOAM Post-Processing 104 February 16, 2021 08:46
[swak4Foam] funkyDoCalc with OF2.3 massflow NiFl OpenFOAM Community Contributions 14 November 25, 2020 03:30
[swak4Foam] Problem installing swak_2.x for OpenFoam-2.4.0 towanda OpenFOAM Community Contributions 6 September 5, 2015 21:03
Problem compiling a custom Lagrangian library brbbhatti OpenFOAM Programming & Development 2 July 7, 2014 11:32
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
