Fluent Meshing 2020R1
Old   October 30, 2020, 08:21
Default Fluent Meshing 2020R1
WALI HASAN
wali is on a distinguished road
Dear CFD Experts,
I am working on cfd analysis of data center, in that model we have a raised floor where my CRAC supply openings and perforated tiles connect the raised floor with data center room.
We prepared the model in spaceclaim 2020 R1 and before import to fluent meshing we did interference option and share topology option in Sapceclaim. Once the share topology operation is performed then we defined boundary name. See attached snapshot
In Fluent meshing 2020R, we are using the watertight meshing workflow, the geometry is available in below we transfer link (https://we.tl/t-PIsZICxOR7). The link contains two files.a) final geometry model with share topology and assigned name selections.b) the model without share topology.
During the meshing, we defined the below sizes based on the geometry specification
Face sizing for different faces (20mm, 50mm, and 100 mm)
Surface mesh (minimum 20 mm and maximum 500 mm for the entire domain).
Consider three inflation layers
For volume polyhexcore mesh size is considered as 640 mm.
Problem: Surface mesh is finishing in 30-40 minutes, whereas assigning boundary types is taking atleast 2-3 hrs and volume mesh is taking 4 hrs. Can you please let us know what is the reason for such long time.
For perfoming the mesh, we are using 4 cores because as per the ANSYS base license we have only 4 cores.
System specification: 132 GB Ram, 32 logical processors
Any recommendations and suggestions will be highly appreciated.
Thank you in advance
Regards
Wali
wali is offline   Reply With Quote
Old   October 30, 2020, 08:39
WALI HASAN
Dear CFD users,
After waiting for 10 hrs, I am getting the below message
Thanks
Wali
Old   October 30, 2020, 10:04
pakk will become famous soon enough
Originally Posted by wali View Post
Dear CFD Experts,
Regards
Wali
What is the volume (m3) of your domain?
pakk is offline   Reply With Quote
Old   October 30, 2020, 11:46
WALI HASAN
The volume is around 1055 m2 x 3.5 m = 3692 m3
Old   November 2, 2020, 02:21
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
you may try to divide domain into several parts and make mesh separately, later assemble in Fluent
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   December 1, 2020, 15:18
Tamil Nadu
pratheeksuresh is on a distinguished road
Dear CFD Experts,
Regards
Wali
Could you please update the link
pratheeksuresh is offline   Reply With Quote
[ANSYS Meshing] Defining a cell zone in ANSYS meshing for fluent Stephen Waite ANSYS Meshing & Geometry 1 July 4, 2022 09:21
Questions regarding meshing and postprocessing in fluent DL598 FLUENT 8 April 21, 2020 12:11
Fluent Meshing sandyy235 FLUENT 3 November 20, 2017 15:53
Transfer named selections from SW to Fluent Meshing the-sted FLUENT 0 May 1, 2016 23:44
Toolbars of Graphic windows in Fluent Meshing Sina.Li FLUENT 1 December 28, 2015 01:09
