November 10, 2020, 11:34 |
Smoke simulation in FLUENT
Mohammed
Rep Power: 13 |
My case is simulating a smoke inside a room.
I have created the whole room domain as as one zone and I created a boundary edge to set it as the smoke inlet while the room is initially containing air only. How can I simulate this case? I tried the species transport model and set the smoke entry as mass flow rate, but I don't know how to set the main domain initially as air. Is this the correct model? should I split the smoke source into another domain ? Thanks in advance |
November 10, 2020, 15:53 |
Lorenzo Galieti
Rep Power: 12 |
Species transport model might be correct (even though smoke is composed of solid particles as well) but you need to define your smoke properties To initialize the domain with only air, there’s a button somewhere in solution initialization to use standard initialization, so that then you can select the exact values with which your solution is started |
November 10, 2020, 18:34 |
#3 | |
Mohammed
Rep Power: 13 |
Do you mean I should define the smoke properties from fluent or as external UDF file? about the initialization I didn't understand how to initialize the domain as air. Can u specify more detailed steps please |
November 12, 2020, 08:13 |
Moritz Kuhn
Rep Power: 17 |
Make the initialization and than go to the initialization panel and choose patch, there it should be possible to define composition.
November 16, 2020, 00:41 |
Mohammed
Rep Power: 13 |
Some questions about flow boiling simulation in Fluent | beastieboys6 | FLUENT | 8 | November 20, 2017 23:47 |
Transient simulation in Fluent | khaham | FLUENT | 13 | March 15, 2016 08:18 |
Acoustic Simulation in Fluent (Pre-defined sound source) | bassam693 | FLUENT | 1 | January 2, 2016 07:06 |
Smoke simulation inside an atrium | Amr | FLUENT | 1 | February 24, 2006 18:00 |
New Fluent Remote Simulation Facility | Paul Bemis | FLUENT | 8 | July 2, 2002 09:18 |
