Radiation through semi-transparent wall (DO model)
Old   June 16, 2020, 11:42
Default Radiation through semi-transparent wall (DO model)
Deutschland
Crystal_Bee is on a distinguished road
Dear community,
I´m new here and looking forward to get help and learn more about Ansys CFD.
I´m working with Fluent to model a double skin facade. I created a 2D Model which consinst of two wall boundaries for the two layers of facade glass and an atmosphere in front of the first layer of glass.
The radiation is implemented on a semi-transparent wall on the outer edge of the atmosphere.
Unfortunately the radiation will not be transported through the semi-transparent wall representing the glass pane of the facade.
Does anybody know why that is? I gave the wall a thickness and defined the material glass. The wall is coupled.
The description of the model and the result are in the pictures:
https://gigamove.rz.rwth-aachen.de/d/id/onbqYsPyD9Bkrg
https://gigamove.rz.rwth-aachen.de/d/id/YLReBoyvsavWJY
I would really appreciate some thoughts on this topic.
Thanks a lot already.
Crystal_Bee is offline   Reply With Quote
Old   November 11, 2020, 08:37
Default Semi-Transparent Medium
Lucas Leocadio Battiston
battiston is on a distinguished road
Originally Posted by Crystal_Bee View Post
Dear community,
Hello CB,
I'm else working with semi-transparent medium. You can trate this medium like a frozen fluid.
Set frozenFlow in fvSolution and its done, you can solve the RTE with P1 or fvDOM.
att,
Lucas L. Battiston
battiston is offline   Reply With Quote
radiation do model
Wrong multiphase flow at rotating interface Sanyo CFX 14 February 7, 2017 17:19
Velocity vector in impeller passage ngoc_tran_bao CFX 24 May 3, 2016 21:16
Monte Carlo Simulation: H-Energy is not convergating & high Incident Radiation volleyHC CFX 5 April 3, 2016 05:41
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 07:00
