December 24, 2020, 11:16 |
The fl process could not be started
André
Rep Power: 10 |
I get the following error after reading a case file (with UDF), and then try to replace mesh:
MPI Application rank 0 exited before MPI_Finalize() with status -1073740940 The fl process could not be started Any ideas what the cause may be? I am using Fluent 2019 R3 , serial Thanks in advance!
Sapere aude! |
March 15, 2021, 09:32 |
Rahand
Rep Power: 10 |
Had the same issue with the same version of Ansys.
Instead of replace mesh, I tried replace zone and thinks seem to work |
Process xxxx: received signal SIGSEGV; The fl process could not be started | Someeee | FLUENT | 1 | October 31, 2018 04:32 |
Error running openfoam in parallel | fede32 | OpenFOAM Programming & Development | 5 | October 4, 2018 16:38 |
the f1 process couldn't be started after 2000 iteration??? | Bmalgil | FLUENT | 0 | May 7, 2018 15:57 |
How to setup a simple OpenFOAM cluster? | TommiPLaiho | OpenFOAM Installation | 3 | October 27, 2013 15:15 |
HELP-error: the fluent process cannot be started | James Willie | FLUENT | 0 | January 24, 2006 11:17 |
