Torque value obtained from ANYSYS Fluent is for wall or air around the wall
Old   December 27, 2020, 03:35
Default Torque value obtained from ANYSYS Fluent is for wall or air around the wall
Jahaan
Jahaan is on a distinguished road
Hi Everyone,
I have a small question.
I have been doing a 2D simulation of flow over a rotating cylinder (Wall). i have used K-Omega solver with derived Y+ values and ran the simulation. I am confused from the derived torque value through Post processing window of Fluent "Reports → Forces → Moments → Select Wall → Print" .
Please advice the derived torque value is of the air rotating over the cylinder OR it is only of Cylinder.
Please share me a good reference to relate my scenario.
Please see the attached images for quick references.
thanks in advance
Jahaan is offline   Reply With Quote
Old   December 28, 2020, 13:54
pakk will become famous soon enough
Stupid question maybe, but aren't they the same?
pakk is offline   Reply With Quote
Old   December 31, 2020, 00:08
Jahaan
Firstly thanks for your reply.
I am bit skeptical about it, if both are same then theoretically calculated torque values of rotating cylinder and the ANSYS torque values of rotating wall are different.
Being a senior member of this page, It will be good if you can be helpful, instead of saying it a stupid question.
I am just starting my self with CFD, trying to explore things out and reaching for help. I would be more happy if i get any help, where i would like to correct myself.
Old   December 31, 2020, 18:42
I didn't mean to say that your question is stupid, I meant that my question might be stupid.
2d flow over a cylinder, fluent, rotating body, torque
Multiphase flow - incorrect velocity on inlet Mike_Tom CFX 6 September 29, 2016 01:27
Running UDF with Supercomputer roi247 FLUENT 4 October 15, 2015 13:41
Problem in IMPORT of ICEM input file in FLUENT csvirume FLUENT 2 September 9, 2009 01:08
air bubble is disappear increasing time using vof xujjun CFX 9 June 9, 2009 07:59
Multicomponent fluid Andrea CFX 2 October 11, 2004 05:12
