Selection of solver in ANSYS Fluent for given mach number |
January 10, 2021, 01:16 |
Ankit Patel
Rep Power: 5 |
Hello everyone!
I am using ANSYS Fluent 2020 R1 for simulation of compressible air. I have attached one sample of isomeric geometry for which simulation have to carried out. The experiment is all ready carried out and I have to carried out simulation for same. Boundary Conditions, Inlet: Pressure (7 bar, Fixed) Outlet: Pressure (Varying between 6.5 bar and 3 bar) Wall: Stationary wall, no slip Target: To find mass flow rate for all boundary conditions The steady, compressible and fully developed turbulent flow is there. From experimental data, the range of Mach number between 0.3 to 1.15 for given boundary conditions. I have carried out simulation for one boundary condition with pressure based solver and density based solver and my mesh is fine for both the solvers. The result by pressure based solver is more nearer to experimental result compared to density based solver. For pressure based solver, SIMPLE scheme is used for PV coupling with second order upwind to other equations. For density based solver implicit formulation is used with second order upwind to other equations. Questions: (1) Which solver results should I consider for given Mach number range for my case? (2) Are there any relation available for Mach number and selection of solver? Thanks in advance. |
January 10, 2021, 07:18 |
Lorenzo Galieti
Rep Power: 12 |
they are bot fine for such mach number conditions. Density based solver is better for high mach numbers. If i have to guess a number, i'd say more than M= 3-4.
I would use coupled solver instead of SIMPLE and stick with the pressure solver. Edit: you seem to speak about experimental data, so I would simply try them both and see which one matches the data better. But as I said, I think for these ranges, nothing so different will happen |
January 10, 2021, 07:24 |
Ankit Patel
Rep Power: 5 |
Ok, Thank you for guiding me.
January 10, 2021, 08:49 |
Ankit Patel
Rep Power: 5 |
As per your edited response, "I should consider the results nearer to experimental results by any these two solver?"
January 10, 2021, 10:06 |
Lorenzo Galieti
Rep Power: 12 |
If it is not too long to run the CFD, run it with both solvers and compare with experimental results you have. Then for any further work use the solver that predicted the best results
If you don’t want to do it, stick with coupled pressure solver |
January 11, 2021, 00:41 |
Ankit Patel
Rep Power: 5 |
Ok, I will do simulation with both solver compare with experimental. If there will any queries then I will contact you.
Again, Thank you for guiding me. |
January 28, 2021, 12:40 |
Ankit Patel
Rep Power: 5 |
Is there any journal paper in which they compare the results of pressure based solver and density based solver with experimental data and give conclusion?
January 28, 2021, 14:04 |
Lorenzo Galieti
Rep Power: 12 |
i googled them -.-
https://hal.archives-ouvertes.fr/hal-01894391/document work from NASA (the name sounds cool yes) https://tfaws.nasa.gov/TFAWS11/Proce...011-AE-001.pdf also this bachelor thesis is fine http://seanbone.ch/site/wp-content/u...n_SeanBone.pdf Are you still stuck that you want to use the density based solver? As I said, either you want to simulate hypersonic reentry or there's no advantage in density based solver |
January 29, 2021, 00:26 |
Ankit Patel
Rep Power: 5 |
I have completed run with pressure based and density based solver and results are good in pressure based with experimental.
I just need the references to add in my report. Thank you |
January 29, 2021, 04:44 |
Lorenzo Galieti
Rep Power: 12 |
good luck then
SimpleFoam & Theater | jipai | OpenFOAM Running, Solving & CFD | 3 | June 18, 2019 10:11 |
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops | avinashjagdale | OpenFOAM Meshing & Mesh Conversion | 53 | March 8, 2019 09:42 |
GenerateVolumeMesh Error - Surface Wrapper Self Interacting (?) | AndreP | STAR-CCM+ | 10 | August 2, 2018 07:48 |
DecomposePar unequal number of shared faces | maka | OpenFOAM Pre-Processing | 6 | August 12, 2010 09:01 |
Unaligned accesses on IA64 | andre | OpenFOAM | 5 | June 23, 2008 10:37 |
