low pressure boundary slip
Old   January 11, 2021, 01:57
Wink low pressure boundary slip
zhangdongjie
zhangdongjie is on a distinguished road
Recently, I was simulating the nozzle with high kn number. Originally, I wanted to write UDF, but I see that some people say that the effect of low pressure boundary slip is very good.
But low pressure boundary slip is like only works in 3D. How can I open this button in 2D?
zhangdongjie is offline   Reply With Quote
Old   January 12, 2021, 14:39
pakk will become famous soon enough
Make it 3D, with the 3rd dimension very small and symmetry conditions. Then you are basically doing 2D.
pakk is offline   Reply With Quote
Old   January 12, 2021, 22:29
Talking
zhangdongjie
I think I may have made a mistake. In the case of 2D and 3D, "low pressure boundary slip" is available. but when I chose "density based" instead of "pressure based". "Low pressure boundary slip" disappeared again.
Old   January 13, 2021, 02:56
Ah, yes indeed. Low pressure boundary slip works only with the pressure-based solver. Anyway, if you are working with low pressures, the pressure-based solver is typically the best choice.
Old   January 13, 2021, 03:55
Talking
zhangdongjie
我模拟的是微型推进器,入口压力1mpa左右,出口速度大概是400m/s。基于压力求解可能不太准确。如果我使用udf的话我不知道温度跳跃的udf要加载在哪里。
Old   January 13, 2021, 03:56
Talking
zhangdongjie
I simulated a micro thruster with an inlet pressure of about 1MPa and an outlet velocity of about 400m / s. Pressure based solutions may not be accurate. If I use UDF, I don't know where the UDF of temperature jump will be loaded.
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 07:38
CFD analaysis of Pelton turbine amodpanthee CFX 31 April 19, 2018 18:02
Problem with SIMPLEC-like finite volume channel flow boundary conditions ghobold Main CFD Forum 3 June 15, 2015 11:14
replacing of shock tube high pressure part with a boundary condition for low pressure immortality Main CFD Forum 0 May 2, 2013 13:30
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
