modeling thermoelectric cooler
Old   November 19, 2008, 10:32
Default modeling thermoelectric cooler
Vivek Sahu
Hello All,
I am trying to model thermoelectric cooler (TEC) inside a fluidic channel. One side of the thermoelectric is facing fluid and the other side is attached to the heat sink. Heat removed from TEC is given by the following equation
Q= S*I*T_c - 0.5 * I^2*Re - (T_h-T_c)/R_th Where S= Seebeck coefficient, I=current, Re=electrical resistance, T_c=cold side temperature, T_h=hot side temperature, R_th=thermal resistance I have written Define_Heat_flux UDF and hooked it after compilation. But Fluent was not showing this macro in the boundary condition panel? But if I interpret the code, then is shows up in the boundary condition panel but I get the following error during initialization:
Error: FLUENT received fatal signal (ACCESS_VIOLATION) 1. Note exact events leading to error. 2. Save case/data under new name. 3. Exit program and restart to continue. 4. Report error to your distributor. Error Object: ()
I am also attaching the UDF file
#include "udf.h"
/* calculates heat flux at the cold side of the SLC*/
DEFINE_HEAT_FLUX(Cooling, f,t,c0, t0, cid, cir)
real alpha = 1e-4; /*Seebeck coefficient*/
real I = 0.5; /*current*/
real resistivity = 0.001; /*resistivity*/
real conductivity = 6.7; /*conductivity*/
real height = 5e-6; /*Height of Thermoelectric cooler*/
real len = 1e-4; /*length of Thermoelectric cooler*/
real width = 1e-4; /*Width of Thermoelectric cooler*/
real chi = 0.5; /*portion of heat flowing back to cold side*/
real area =len * width; /*area of the SLC(=length * width) */
real Re = resistivity*height/area ; /*resistance of the SLC layer*/
cid[0]= - chi*I*I*Re/area ;
cid[2]=-alpha*I/area ;
Please advise me how can I model this. Thanks
Vivek
Old   February 6, 2021, 16:22
ahmet kaya
blacksatellite is on a distinguished road
Originally Posted by Vivek Sahu
;154859
Hello All,
#include "udf.h"
Vivek
did you solve your probblem ı have the same
blacksatellite is offline   Reply With Quote
Icepak thermoelectric Nikhil Lakhkar FLUENT 8 March 25, 2021 12:00
When Introducing Radiation -System becomes cooler? Daniel CFX 5 March 2, 2009 11:12
turbulent modeling with wall functon(or modeling) yoo seon oh Main CFD Forum 5 July 4, 2007 14:06
v2f modeling akula FLUENT 2 September 12, 2003 12:04
Fan modeling Anders Jerhamre Main CFD Forum 1 October 11, 2001 05:26
